I'm going to be installing a new CPU some time soon and would like know anything important before doing so. You know, such as the paste and stuff. I also have a pretty nice heat sink and think that I may use the stock that comes with the processor but I'll give a link so you can give your opinions.
My setup:
Motherboard: ASRock K10N78
http://www.asrock.com/mb/overview.asp?Model=K10N78
CPU: AMD Athlon II X4 630 Propus 2.8GHz 4 x 512KB L2 Cache Socket AM3 95W Quad-Core Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103704&nm_mc=OTC-Froogle&cm_m...AMD-_-19103704
Heat Sink: Thermaltake - 120mm CPU Cooling Fan
http://www.bestbuy.com/site/Thermaltake+-+120mm+CPU+Cooling+Fan/8990489.p?id=121800708...&skuId=8990489
Thanks for any help![]()
Results 1 to 12 of 12
The motherboard and cpu are ok,if you want to get a better heatsink that cost less this is the one to get,i bought it.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233003
Also use arctic silver 5 for the thermal paste.I think,therefore i am a hamster. -
When I use the Arctic Silver do I use it all? and do I spread some on top of the CPU and the heat sink?
Also that heat sink looks pretty big lol, must work pretty good tho.
thanks for the reply -
The Arctic Silver, you will use very little, about the size of a pea........Then you spread it out in the CPU only.....
Nice Video here :
http://www.youtube.com/watch?v=RAhlgMz2www -
Arctic Silver is the stuff...but this is one of those situations where too much is as good as too little. The pea size recommendation is correct.
Ideally, you want about the thickness of one layer of magazine page before compressing the heatsink against the CPU. The thermal compound is only to fill the imperfections between the CPU and the heatsink. Less is better.
From Arctic Silver: http://www.arcticsilver.com/arctic_silver_instructions.htm
Most new CPU heatsinks come with tape type thermal compound. It works well enough for most users. If not, you can wash it off with 99% isopropyl alcohol after scraping off the majority with a plastic credit card, being careful not to scratch the heatsink surface. -
ok! thanks for the help everyone.
anyone have a suggestion about the heat sink? i'm not sure if the one I have would be better than the stock that it comes with or not.. -
IMHO I'd use Artic Cooler MX-2 thermal paste...I use to use Artic Silver but with today's newer cpu's MX-2 & MX 3 is the preferred thermal paste along with IC-7 and OC Freeze.
I'm biased so I'll suggest to you to buy a Cooler Master Hyper 212 Plus. It's been getting good reviews and it has a solid bracket where's today's newer cpu coolers are heavy and huge. I use the Cooler Master Hyper 212 first generation cpu cooler.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
http://www.svc.com/rr-b10-212p-gp.html
Here's a link for thermal paste, all different brands:
http://www.petrastechshop.com/thinma.html
Just my 2 freaking cents!
The Cooler Master Hyper 212 Plus is pretty well the same style hsf that i linked.Heres a link to comparison tests of hsf.
http://www.frostytech.com/articleview.cfm?articleid=2233&page=4I think,therefore i am a hamster. -
I'm using an OCZ Vendetta 2 for my C2Q Q9550. The Vendetta 2 is the same physical size as the Hyper 212 Plus. I used Arctic Silver MX-2. Great stuff. My CPU temps range from 20-40 C depending on how much of a load I'm putting on my system. Normally the temps hover around 30.
OCZ Vendetta 2:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835202007
http://www.ncixus.com/products/29311/OCZTVEND2/OCZ%20Technology/ -
Thanks a lot everyone, I think thats all I need to know.
I'm going to go with the Artic Cooler MX-2 thermal paste and the Cooler Master Hyper 212 Plus.
All at very reasonable prices. -
Your welx! The products you chose won't disappoint you.Originally Posted by HotDamn!
Installing XP on a used PC
By CSULB71 in forum ComputerReplies: 24Last Post: 21st Nov 2008, 11:05 -
installing
By lindakay in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 4th Mar 2008, 07:13 -
installing Binaries
By mahanpots in forum ffmpegX general discussionReplies: 1Last Post: 14th Dec 2007, 10:16 -
Installing Aften
By jsm1963 in forum AudioReplies: 2Last Post: 29th Nov 2007, 18:38 -
CPU-Z reading for Intel Allendale cpu
By budz in forum ComputerReplies: 11Last Post: 8th Jul 2007, 19:33
