    Dec 2009
    I had 10 videos converted using Divx converter with menus. I do not have the original videos anymore, however I need to see how I can "unconvert" this dvix file I created. I need to to this to be able to retrieve the individual videos. It plays fine on the Divx player and a divx ultra certified device. But, I need to be able to extract the videos form the 7gb file. Is there a tool that will undo what Divx converter did?
    USA
    You could change the extension to .avi from .divx and you should have an ordinary Divx file. Then you could use an video editor to separate the individual clips, if that's what they are. But there is probably a more correct way to do this. Others may have a better idea.
    And welcome to our forums.
    Dec 2009
    Thank you redwudz, but renaming it will only allows me to play the first video. What editor do you suggest?
