Here is a photo of the storage manager.
I'm not sure what I did, but I have 11MB unallocated space on the boot drive (Don't know why or really what that means)
But then I also have a Drive F on my other 1.5 Terabyte drive that shows up. In explorer it shows up in red...not sure why...
Can someone give me a hand...
				Results 1 to 9 of 9
	Smile Smile Smile
	I see nothing out of the ordinary in your ss
 If you view your HDD's in Explorer as tiles, if they are red that means they are full
 ps 11mb is neglible
 ocgw
 peacei7 2700K @ 4.4Ghz 16GB DDR3 1600 Samsung Pro 840 128GB Seagate 2TB HDD EVGA GTX 650
 https://forum.videohelp.com/topic368691.html
	Your boot drive is C:, least that's what the pict shows
 Are you booting to multiply OSs?
 that 11mb might be a boot manager partition
	exactly, he can delete the volume, and reformat the drive to recover the 11mb, but it isn't worth itOriginally Posted by stiltman
 ocgw
	I would do it just to get rid of it. I hate logical drives and suchOriginally Posted by ocgw
	Many boot drives have a second partition, about 10 - 100MB or so, that is created during the OS install. I would just ignore it. It's more common on laptops and used for a recovery partition. On your system, probably something the OS uses.
 When I did a clean install of W7 on my Intel PC with a new 150GB Raptor drive, W7 created a 100MB partition and marked it as 'System Reserved'. It only shows up in 'Computer Management.'
 If you were to eliminate it, might cause problems somewhere. And it's so small, not worth bothering with.
 EDIT: Unallocated means it isn't formatted, so probably not used for anything. If you did format it, you would end up with a basically useless 11MB HDD.
	if it is a recovery partition like vista and w7 make during certain types of installs and you try to delete it and join it to the rest of the disc, you will just trash the entire drive. that special area is completely non-standard by design. --
	My point...not on the boot drive
 OEM's usually format the drive and don't give it a letter
	good point, but he did say it is showing as red so I am assuming it is almost fullOriginally Posted by stiltman
 ocgw
  DVDFab HD Decrypter : Is DVD to HDD and Blu-ray to HDD decryption FREE?By Bonie81 in forum DVD RippingReplies: 2Last Post: 8th Jun 2011, 15:28
  Copying from standalone hdd recorder's hdd to pc hddBy flez in forum ComputerReplies: 7Last Post: 6th Dec 2010, 07:17
  Funky mp4 file.By ADAM_SMAILI in forum Video ConversionReplies: 2Last Post: 3rd Sep 2010, 23:23
  Correcting Funky Concert LightingBy callmebc in forum EditingReplies: 2Last Post: 3rd Apr 2009, 13:18
  HDD swap! Faulty 'Funai HDR-B2735' vcr/hdd/dvdr ... use HDD in a JVC ???By StuR in forum DVD & Blu-ray RecordersReplies: 6Last Post: 9th Oct 2008, 13:38
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
