Hi. I'm trying to convert some MKV files with TMPEGEnc Express 4.0 (version 4.2.3.193). I can extract the subtitles and audio from the MKV file, but usually convert the video by directly inputing the MKV file on TMPEGEnc and converting it into m2v files. I do this because I want to burn them on DVD and need the m2v as video source for DVDLab Pro. However, since I installed Windows 7 on my PC I still convert the files, but now I get the subtitles hardcoded on the m2v file (the subtitles in the files I've tried so far are .sub with .idx and .srt). However, this did not happen when I had the same program version installed on Windows Vista. Does anyone know what may be going on and how can I keep this from happening? Thanks for the help!
It's probably a subtitle filter that is enabled by default.
If you play the mkv in windows media player do you see the subtitles?
Have you installed any codec packs or ffdshow or vsfilter? -
Well, my windows media player doesn't open mkvs, I don't know why, probably lacking some codec. But I have installed Combined Community Codec pack 2009.
Ah, yes. I uninstalled CCCP and installed it again. Now I can't even open the MKV files on TMPEGEnc
Remove subtitles etc from MKV files
By jack616 in forum EditingReplies: 11Last Post: 30th Dec 2013, 01:21 -
How to remove embedded subtitles from mkv
By imars99 in forum SubtitleReplies: 9Last Post: 24th Aug 2011, 03:06 -
Remove any subtitles has an mkv file.
By fits79 in forum SubtitleReplies: 6Last Post: 4th Aug 2011, 17:49 -
Trying to remove subtitles from a mkv with mkvmerge
By vato76 in forum Newbie / General discussionsReplies: 1Last Post: 30th Oct 2010, 23:53 -
Converting MKV subtitles to SRT
By Xpenguin17 in forum SubtitleReplies: 7Last Post: 9th Oct 2009, 17:59
