Hey guys, it's been a few years since I've worked with video, but I'm looking to get back in. What I'm looking for is a capture card that can capture in 720p through component cables (or HDMI too, I suppose)? Also, it would need for it to output the video signal going in to a second display without any delay. I'll be capturing video game footages, so it's crucial there's no delay on the output so I can actually play the game while recording.
Does a card like this exist?
Thanks in advance!
Results 1 to 16 of 16
Hauppauge HD-PVR
It is an external box that converts analog component to h.264 fed over USB2.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Originally Posted by fritzi93
Also, what resolutions can it capture it? Can it capture something both 480p and 720p? And do you know how big the file size tends to be for the latter, say for an hour's worth of footage?
Oh, and have you had any issues with it crashing?
Thanks! -
2) No delay on pass-through.
3) It records at the input resolution. It can't do 1080p, though.
4) File size is all bitrate and run-time. Get a bitrate calculator. Like this:
https://www.videohelp.com/calc
More info on the Hauppauge HD-PVR here:
http://www.newegg.com/Product/Product.aspx?Item=N82E16815116030&cm_re=hd_pvr-_-15-116-030-_-Product
And here:
http://www.hauppauge.com/site/products/data_hdpvr.htmlPull! Bang! Darn! -
AFAIK, it's the only (consumer) device of its kind. I'm completely satisfied with mine.
It's a hardware capture device that captures via USB to H.264 in one of three containers: TS (transport stream), M2TS (MPEG transport stream), or MP4. I use TS. Be advised that H.264 is hard to edit, it's highly compressed. There are no frame-accurate freeware H.264 editors. I use tsSniper, which is close enough to accurate for removing adverts. TSPE (payware) is supposedly frame-accurate.
I *think* edDV was saying decompress to some intermediate lossless codec before opening in Vegas.
Good luck.
[EDIT] The bundled Arcsoft Total Media Extreme is very good. It has the capture module, Blu-Ray/AVCHD editing and authoring, format conversion, and Digital Theater, which is the best damn software Blu-Ray player I know of. IMO, the player alone turns a good deal into a great deal. I don't use the editing/authoring or conversion modules, there are better choices, but hey, they do work.Pull! Bang! Darn! -
Thanks again for all your help! -
No, the conversion module is for portable formats. Use something else.
Pull! Bang! Darn! -
Vegas Pro will edit h.264 in an M2TS wrapper but if your computer profile is correct, it will bog down. I'd suggest converting to uncompressed or a digital intermediate before using Vegas but if your CPU is a 1.6GHz, that won't work either. You need at least a Core2Duo.
Originally Posted by edDV
Thanks for the response. -
I'd love to get a powerful laptop to work on for both ease of use and portability--would I be able to find one that would work well with the Hauppauge HD-PVR and Vegas? Or would I be better off getting a desktop?
Thanks!
I can't capture in 720p with my Hauppage HD PVR
By Lotus Prince in forum Capturing and VCRReplies: 27Last Post: 25th Jan 2012, 23:34 -
Can my capture card carry 720p?
By MrBlack in forum Capturing and VCRReplies: 4Last Post: 25th Jan 2012, 20:41 -
Hi8 capture- Suggestions for Harddrives and Capture Cards?
By CMP1223 in forum Capturing and VCRReplies: 7Last Post: 10th Jun 2011, 23:05 -
Connecting XBOX 360 with 720p Plasma HDTV: So HDMI or Component Av Cable??
By jajabinks92 in forum DVB / IPTVReplies: 2Last Post: 29th Nov 2008, 08:16 -
Anyone ever do component out to a 720p TV?
By SignedupGuest in forum Newbie / General discussionsReplies: 23Last Post: 9th Jun 2007, 17:18
