Hi,
I've a DV AVI video, so I splitted the video (by timecode) with DVdate.
Everything is fine, the scenes are all created.
I started to edit the video, but there is frustrating problem with the transitions
I want to add a cross effect between 2 scenes, but Vegas just puts another frame in the middle of the transition
It put's a frame of the end or beggining from one of the 2 scenes
I don't understand why there is such a problem for just a transition (is it a bug or am I doing something wrong?)
I hope someone can help me out
EDIT I use Sony Vegas 9
The flag once raised will never fall!
You need to make sure the clips overlap, either on the same timeline or across two timelines, then drop the transition onto the overlap. If you use two timelines then you will have to manually set the length of the default fade, then drop the transition onto the fade area to replace it.
Read my blog here.
Just split the file where you want to put the transition by pressing the "s" button on the keyboard then insert the transition.
Originally Posted by guns1inger
I did find other related topics but there wasn't a answer
again thank you and lowellriggsiam also thanksThe flag once raised will never fall!
How to control transition length in Vegas Pro 10?
By gutterboy in forum EditingReplies: 4Last Post: 14th Oct 2011, 15:12 -
Problem with adding transition effects to HDV footage in Vegas 9 Pro
By btodorov in forum EditingReplies: 4Last Post: 24th Aug 2009, 14:46 -
Vegas 8 - Transition help
By stantheman1976 in forum EditingReplies: 14Last Post: 30th Aug 2008, 07:29 -
Using Pinnacle transition FX in Vegas?
By NoRulez in forum EditingReplies: 0Last Post: 9th Sep 2007, 12:59 -
using a book page turning transition in vegas?
By Rudyard in forum EditingReplies: 1Last Post: 11th May 2007, 04:06
