After couple of weeks of silence, now I got the blue screen again. Yesterday one, today one...
How can the computer run normal for 3 weeks and now start again?
Here are the messages:
Yesterday's messange - IRQL not less or equal
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7600.2.0.0.768.3
Locale ID: 1033
Additional information about the problem:
BCCode: a
BCP1: 00000118
BCP2: 00000002
BCP3: 00000001
BCP4: 82D0ED11
OS Version: 6_1_7600
Service Pack: 0_0
Product: 768_1
Files that help describe the problem:
C:\Windows\Minidump\120809-23166-01.dmp
C:\Users\AlinTatoC\AppData\Local\Temp\WER-37050-0.sysdata.xml
Today's error - memory management
Problem signature:
Locale ID: 1033
BCCode: 1a
BCP1: 00041284
BCP2: 20BBF001
BCP3: 0000DDD0
BCP4: C0802000
Service Pack: 0_0
Product: 768_1
C:\Windows\Minidump\120909-22978-01.dmp
C:\Users\AlinTatoC\AppData\Local\Temp\WER-145751-0.sysdata.xml
I want to remind you that I haven't changed anything in the last 3 weeks so that's why I am puzzled why I have the blue screen again...
Results 1 to 11 of 11
Both errors are indicative (but not definitively, so I can't say for absolutely certain) of a faulty memory stick. I would certainly bet that's what it is. This would also explain the intermittent nature of the failures. Sometimes it works, sometimes it burps.
If you have more than one memory stick, try pulling one out and rebooting. If you get BSOD, replace it and pull out another memory stick. It's a slow, laborious process, but it can help you isolate the culprit. -
Ok, but 3 weeks ago I had different memory sticks and I still had problems with blue screen. Somehow I can't believe that I am that lucky and this new memory are bad...Originally Posted by filmboss80
Could it be from something else? -
Have you changed or upgraded any system software? Did you upgrade Flash?
Could possibly be video driver related. Also overheating of the system can create a blue screen.
I had Blue Screens for months - almost every day. I changed everything - RAM, video card, etc. Finally I reinstalled XP from scratch and haven't had a blue screen in 6 months (I did upgrade to a beta version of Flash, which immediately caused blue screens, downgrading fixed it)."Quality is cool, but don't forget... Content is King!" -
No, I haven't changed the system software, still running with Windows 7, 32bit version. I didn't upgrade flash either.Originally Posted by Soopafresh
Overheating, don't know what to say about that because my case is new and has good ventilation inside, and I don't even play games on my pc.
Motherboard and videocard are new, 1.5 months, RAM is new, 1 month so I don't know why I continue to have this issues.
Actually nothing special, surfing on the internetOriginally Posted by lowellriggsiam
I was actually wondering, could it be from my external hard drive? Probably not, but just wanted to ask... -
Random shut downs sounds like either faulty RAM, or CPU over heating issued. Have you run memtest to check your RAM?
No, not yet, but I will run the test to see if I get any errors.Originally Posted by lowellriggsiam
one suggestion, remove the motherboard battery, looks like alarge watch battery, for , say, 2 hours, then re insert and re start. it resets the bios etc, cannot do any harm (he said famously)
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
yes it seems to need a period of time to clear the cmos, also if you can, just ensure everything is fitted well inside the case, remove the power from the outlet, earth yourself, just ensure evrything is seated properly.
HELP! Black screen/Blue Screen problem
By will7370 in forum ComputerReplies: 2Last Post: 1st Apr 2012, 09:30 -
Blue Screen of Death (BSOD)
By MrZ in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 4th Dec 2009, 04:31 -
Blue screen?
By alintatoc in forum ComputerReplies: 19Last Post: 1st Nov 2009, 06:53 -
what's a blue screen?
By aruwin in forum ComputerReplies: 8Last Post: 23rd Sep 2009, 08:56 -
Blue Screen Of Death
By Squid_uk in forum ComputerReplies: 15Last Post: 31st Mar 2008, 14:35
