heyho,
id appreciate some help. For the life of me i cant figure out how to make EVR output the correct colorspace in mpc-hc. Whenever i play a YV12 source it outputs in NV12, causing the colors to be all wrong as in "soft" and a bit "yellowish"
Ive tried ffdshow and coreavc, tried disabling/enabling output colorspaces in both, tried colorspace conversions, tried different input / output levels, tried shaders, tried changing nvidia's output range, etc etc.. it always outputs in nv12 when using EVR. Didnt find anything usefull with google either. If i didnt provide enough information, apologies and do tell
Anybody got any ideas? Muchos gracias!
yeah ive tried forcing all kinds of outputs, it always ends up in nv12. However after futzing around with it some more ive noticed that its not even EVR's fault but something to do with directx itself. DX's mixer output is nv12 regardless of what renderer i use, with dxva enabled or not. Except with vmr9 it doesnt use any mixer and leaves the colorspace as is and correct. But vmr9 in vista just plain sux and doesnt work properly.
Any ideas?
edit: scratch that, vmr9 colors are wrong too. Theres definitely something weird here, either its directx or some other thing completely. With opengl in vlc i dont have any problems the colorspace is correct.
MKV file sometimes syncs wrong with MPC
By Sc4rf4c3 in forum Newbie / General discussionsReplies: 2Last Post: 15th Feb 2012, 11:46 -
EVR on XP SP3 with MPC-HC
By THX-UltraII in forum Newbie / General discussionsReplies: 0Last Post: 10th Sep 2008, 06:30 -
VLC/MPC Video Output Problems Suddenly
By usarin in forum Software PlayingReplies: 4Last Post: 24th Jun 2008, 12:29 -
EVR via MPC
By ckamc in forum Software PlayingReplies: 0Last Post: 23rd Apr 2008, 22:48 -
proper output for MPC directshow?
By SignedupGuest in forum Newbie / General discussionsReplies: 0Last Post: 9th Feb 2008, 17:17
