Hi,
I reloaded my OS to Windows 7 and I can't get AVI-mux to work. I'm not sure what the issues is. Anyway, is there another program I can use to mux AVI?
Thanks.
There's also DivX Mux GUI, which makes a file with a .divx extension, but you can change to .avi if your player doesn't support .divx. All players that are DivX-certified will support the .divx extension, along with muxed SRT subtitles and multiple audio tracks, which is what I use DivX Mux GUI for.
http://labs.divx.com/DivXMuxGUI
AVI-Mux GUI problem
By toni-boy in forum DVD & Blu-ray PlayersReplies: 8Last Post: 23rd Oct 2010, 13:37 -
MUX Mp3 Into AVI
By onesikgypo in forum LinuxReplies: 4Last Post: 13th Apr 2010, 02:05 -
AVI-MUX: How do I mux avi file with a setting of "preload=512?"
By Stealth3si in forum EditingReplies: 3Last Post: 1st Feb 2010, 11:10 -
Question why AVI-Mux GUI cuts down file size
By jimdagys in forum EditingReplies: 2Last Post: 16th Apr 2009, 04:18 -
h264 + ac3... .mkv mux in synch, .avi mux out of synch...
By homerpez in forum Video ConversionReplies: 0Last Post: 5th May 2007, 06:42
