I just bought a MP4 player, primarily for playing mpeg2 videos. Mpeg2 recorded from DVB-S (satellite) is ok. But mpeg2
converted from AVI (by Super application) has out-of-sync sound. It is firmware problem, but workaround exists - the way to produce good file is to use 'MEncoder' option (not 'ffmpeg'!) with 48K sound in Super. So far so good, but another problem - the TV-Out from the player can't set the picture format (4:3, 16:9, 4:3 letterbox), it always stretches video to 4:3. Thats bad for 16:9 videos. So I would like to convert my 16:9 mpeg2 files to 4:3 letterbox (black bars on top and bottom encoded in picture). And there goes problem with Super - Crop/Pad option is enabled only with 'ffmpeg', no chance to do it with 'MEncoder'. Does anybody have any ideas how to do it? Does exist some other utility which can simply convert mpeg2 16:9 to mpeg2 4:3 letterbox? Slight loss of quality after encoding is tolerated.
Or better - does anybody know what's the difference between 'MEncoder' and 'ffmpeg'? What can be so different in encoded files, so the sound is out-of-sync? Can this be changed/repaired afterwards?
Thanks.
Same here: Ditched Super as it was not super any more...Originally Posted by guns1inger
There are a few different versions of Xvid4PSP (especially since the official developer has stopped with it, and custom versions started to appear). The latest versions allow to make batch processing of files (not sure about saving batch tasks).
Super: converting .dv to mpeg2 settings
By K1JJS in forum Video ConversionReplies: 8Last Post: 8th Mar 2012, 13:19 -
AVI to DVD-MPEG2 using SUPER
By hemang in forum Video ConversionReplies: 0Last Post: 19th Jul 2009, 23:25 -
Can I remove color and letterbox MPEG2 video without losing quality?
By gamgamman in forum EditingReplies: 3Last Post: 10th Jul 2008, 23:22 -
Converting .VOB or MPEG2 from 16:9 to 4:3 Letterbox
By g1275 in forum EditingReplies: 6Last Post: 17th Aug 2007, 09:11 -
Anyone get Super MPEG2 conversions to be DVD compliant?
By Rudyard in forum Video ConversionReplies: 7Last Post: 1st Jul 2007, 19:08
