    Dec 2009
    Singapore
    Currently, i'm using cccp codec and I used mkvmerge and extract to get the audio out. The audio was supposed to be 24mins long, but instead it dragged all the way till 26mins. And I used meGUI to encode video & audio together, it also says 26mins. And after encoding them together, there was nothing at the last 2 mins. Also for your information, I'm using Windows 7 Home Premium.
    However, the audio works on Klite Codec pack. But I'm no good with Klite Codec Pack as there's some subtitle issues with it. Please do help me with it.
    Probably something wrong with the mkv...even if you can play it.
    But give more information. What is the audio codec in the mkv?
    What are you going to convert to? Try another converter like handbrake, xmedia recode.
    Oct 2005
    666th portal
    what is your source? use mediainfo and post the info from the text view. also what are you trying to do?
    Dec 2009
    Singapore
    Thanks for the reply. I'm trying to hardcode some subtitles into the show, with the exact same mp4 format. But after encoding, it shows 26mins instead. This is extracted from MediaInfo:
    General
    Complete name : C:\Users\fi3ryfalc0nZ\Desktop\OkashiiSubs\[Okashii-RyRo] Inazuma Eleven - 1\[Zero-Raws] Inazuma 11 - 01 RAW (1280x720 x264).mp4
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom
    File size : 289 MiB
    Duration : 24mn 39s
    Overall bit rate : 1 636 Kbps
    Encoded date : UTC 2008-10-05 04:59:48
    Tagged date : UTC 2008-10-05 04:59:48
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 3 frames
    Codec ID : avc1
    Duration : 24mn 39s
    Bit rate mode : Variable
    Bit rate : 2 852 Kbps
    Maximum bit rate : 8 979 Kbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Variable
    Frame rate : 23.976 fps
    Minimum frame rate : 7.992 fps
    Maximum frame rate : 95.923 fps
    Resolution : 24 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.129
    Stream size : 254 MiB (88%)
    Writing library : x264 core 65 r997 65b837f
    Encoding settings : cabac=1 / ref=3 / deblock=1:-1:-1 / analyse=0x3:0x111 / me=umh / subme=7 / psy_rd=0.5:0.0 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=0 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=1 / scenecut=40(pre) / rc=crf / crf=21.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=16 / ip_ratio=1.40 / pb_ratio=1.30 / aq=0
    Encoded date : UTC 2008-10-05 01:21:29
    Tagged date : UTC 2008-10-05 05:00:25
    Audio
    Format : AAC
    Format version : Version 4
    Format profile : LC
    Format settings, SBR : No
    Codec ID : 40
    Duration : 24mn 39s
    Bit rate : 192 Kbps
    Maximum bit rate : 219 Kbps
    Channel(s) : 2 channels
    Channel positions : L R
    Sampling rate : 48.0 KHz
    Resolution : 16 bits
    Stream size : 33.9 MiB (12%)
    Encoded date : UTC 2008-10-05 01:34:29
