Hello, i ´m new at the forum.
I have already rip,with SmartRipper, Shreck in Spanish,without any extras,languajes or subtitles.
Well,i have a vobs and and ifo file. My question is:What I need to burn a DVD fully functionaly in a Standalone DVD player?
¿What i need to do?
Thank you.
You have to read a guide. Have a look at the "how to..." sections.
Well.... What is the guide?. :oops:
I don´t kow if i need to modify the ifo file generated or not.Whe i rip the movie is it preparated to be burn in the DVD? or i need to do anytingh else...
Please what is the exact guide? :wink: -
Actually, you may have already started down the wrong path if you want to use a dvd writer to create a dvd copy of your movie, unless you ripped the whole dvd to disk first using the "backup" option. If you coppied the whole dvd to the hard drive (normally takes at least 7 Gig), then take a look at the dvd to dvd-r guides on www.doom9.net. If you didn't rip the whole dvd, but, as I suspect, like me when I started, you ripped the "main" movie chain using the "movie" option (normally runs between 4 and 5 gig), then you still have some hope. run IfoEdit, choose "Create IFOs" and point it at the VOB files for the movie. After some processing time, you should get the video_ts and vts_01_0 ifo and bup files. Now you have enough to make a playable dvd. Exit IfoEdit, re-start it, choose "open" and point it at the newly generated video_ts.ifo file. Choose "Get VTS Sectors" and click O.K. untill it stops processing, save back your ifo. Chek the result with a software player (PowerDVD does the best job), and use your favorite burner to burn the dvd.
One point to note on this procedure (hence my comments at the start), when I tried it, I noticed that either SmartRipper or IfoEdit had an anoying bug which meant that the movie chapters quite often wern't re-generated in the right place, and moreover, the movies played fine on my PC, but when playing in my player, some of the chapters would cause the time counter to be re-set (zero'd), which wasn't a big deal, except that my player paused for a split-second each time the elapsed time was re-set on a chapter boundary (much like what sometimes happens on a layet transition , making it very anoying watching). You may get more lucky that I was.
Batch rip SRTs from VOBs?
By Luth C in forum Newbie / General discussionsReplies: 10Last Post: 28th Apr 2012, 20:47 -
BD Rip worked only once, now can't rip BDs successfully
By thestrangebrew in forum Blu-ray RippingReplies: 2Last Post: 1st Apr 2012, 08:30 -
Free Software to rip multiple PGC's in one hit to individual vobs
By Ads79 in forum DVD RippingReplies: 2Last Post: 24th Apr 2010, 04:25 -
Convert non-compliant VOBs to "good VOBs"
By pmolson in forum Video ConversionReplies: 3Last Post: 24th Oct 2008, 10:52 -
my rip spec hell - from a ts. folder to rip specs - how?
By marinebc11 in forum MacReplies: 5Last Post: 26th Nov 2007, 20:28
