Hi all,
Well, after some years, it`s time to go to High Definition; I`ll need a new computer fast enough to edit AVCHD/MPEG2-HD files, does anyone have suggestion on a good combination of MOBO + CPU + memory modules ?
Budget is not necessarily an issue, but of course I don`t wanna go bankrupt, I just need it to be fast enough to edit HD files using Premiere Pro CS4 without any add-on softwares.
Generally I prefer to stick to Pentium processors cause these seems more compatible, I have had better experiences with them, also ASUS mobo are my favorites as well.
A suggestion on a camera would be highly welcomed as well;
Thank you,
Zetti
AVCHD is difficult to edit natively, very cpu intensive and sluggish on the timeline. Do a search an you will find 100's of threads on this topic. Many people resort to using digital intermediates or proxy editing. An i7 at stock speeds can handle 1 stream comfortably.
CS5 next year will bring GPU acceleration to Premiere, until then , it's still difficult to edit natively without the workarounds mentioned - especially when you add in effects/transitions, multiple streams
Choice of camcorder depends on your goals/needs , price range, features, ease of editing, media choice etc... have a look at review sites including camcorderinfo.com
Tried to upgrade computer..
By esmitty82 in forum ComputerReplies: 10Last Post: 2nd May 2010, 12:52 -
Computer Guys Braggin' Time: What have you built that AIN'T a computer?
By ahhaa in forum Off topicReplies: 22Last Post: 8th Feb 2010, 15:19 -
Video Editing: New Computer Or Upgrade?
By Jedi5 in forum ComputerReplies: 3Last Post: 10th May 2008, 18:32 -
Time for a Video Card Upgrade?
By dj4monie in forum Media Center PC / MediaCentersReplies: 21Last Post: 19th Dec 2007, 03:35 -
Time to upgrade, barebones computers
By capman21 in forum ComputerReplies: 20Last Post: 20th Sep 2007, 09:40
