I created DVD disk from videos (.mts files) by using Pixela software (original what comes with HF20 camera) and result is terrible. Video have combing effect. What I am doing wrong?
post a screenshot to illustrate
how are you viewing this? PC? DVD-Player?
just a guess, but it might be resizing the interlaced fields incorrectly -
effect like in wikipedia http://en.wikipedia.org/wiki/File:Interlaced_video_frame_(car_wheel).jpg
I view it on same PC, and sure that this is due to interlaced fields, but how to change that in Pixela Image mixer?? -
Turn on your deinterlacer in your PC software (e.g. VLC enable deinterlacing in the options), or your standalone DVD player will do it automatically.
If you see similar artifacts even with the deinterlacer, or thicker line artifacts, then it likely resized it incorrectly -
Yes it works, thanks, that was problem with a player. That works on Windows Media Player 11, but on VLC still little of that effect. What would be the best deinterlacing mode? There are different options. - Blend, Mean, bob, linera etc.
Bob is the better one IMO, because it keeps the temporal resolution i.e. it plays at 60 pictures/s (or 50 for PAL land). The others will play at 1/2 that. But it is slightly more CPU intensive, but for standard definition MPEG2 material this is not an issue on modern PC'sOriginally Posted by HF20_user
You might have different personal preference, so try them all out
VirtualDub *.MTS "Unable to set filename on media detector:hr=80040200"
By Innomen in forum Video ConversionReplies: 15Last Post: 27th Aug 2012, 09:24 -
"Live" picture effect - pictures end up "filmized"
By ANOther1676 in forum Software PlayingReplies: 10Last Post: 14th Oct 2011, 12:59 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
Annoying "combing" affect on AVI files
By djdust in forum Newbie / General discussionsReplies: 1Last Post: 27th Feb 2011, 19:01 -
Staxrip: "Constant Quality" vs. "Exact File Size"
By FallenAngelII in forum Video ConversionReplies: 1Last Post: 9th Aug 2007, 18:40
