Does anyone know of any simple software to convert the audio of an MPEG2 file from AC3 to MPEG1 Layer2? I have a video player for my motorhome that only plays the sound if it is in MPEG1 Layer 2, and a lot of my MPEG2 files have the audio in AC3.
Thanks, John
Results 1 to 9 of 9
regards, jrisch
I'v looked at the two products suggested but they only seem to convert standalone audio files. My problem is that I have MPEG2 files that contain both video and audio. Gspot shows the embedded audio as being AC3. The player/recorder I want to use them in plays the video OK but no sound. It does play video and sound from its own recorded files that Gspot shows the embedded audio as being in MPEG1 Layer 2.
Any ideas, anyone?regards, jrisch -
Well, yes and no. BeSweet can convert the audio from VOB files. If it won't handle MPG (you're not being clear because VOBs contain MPEG-2 video), then either try renaming the MPG or whatever it is to VOB, or (better, probably) demux first. You'll have to demux anyway if you intend to remux the MP2 audio along with the video back to MPG or whatever you want. As for demuxing, open the MPG or whatever it is in DGIndex and then File->Save Project and Demux Video. That's one way.Originally Posted by jrisch
You seem to think you can take an MPG file and reconvert the audio only, without demuxing or remuxing anything, and it ain't gonna happen. -
You're right that the audio has to be demuxed first but decoding "is" demuxing so e.g. a FFmpeg command line like below should be able to do it in one go.Originally Posted by manono
FFmpeg.exe -i "c:\source.mpg" -vcodec copy -acodec mp2 -ab 192k -ar 48k -ac 2 -f vob -y "c:\output.mpg"
FFmpeg will only pick out the left/right channels if it's 5.1 ac3 but the mentioned audio tools do the same.
If the audio is out of sync, try to add "-async 2" to the command line. -
You can do it in Womble MPEG Video Wizard DVD (make sure you get this one as it supports AC3 http://www.womble.com/ - download the trial. Import the mpeg2 file into the time line and under the audio tab select mpeg2, 1 or mp3 or wav as the audio. Eport to a new MPEG2 file. The video will be stream copied whilst the audio will be re encoded.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Good one, netmask. I didn't realize Womble had that ability. And your suggestion is a good one I'm sure, Chris K, but, I for one, won't touch a CLI app if I can possibly avoid it. Perhaps jrisch feels differently.
Many thanks, guys for all your help. I've tried both Womble's MPEG Video Wizard, very slick and full featured, though a bit pricey for my limited requirement, and FFmpeg. Both did the job in a single step. FFmpeg's CLI doesn't really worry me as I don't need to change all the parameters, and I can easily front-end it with Excel.
Thanks again.
Regards, jrischregards, jrisch
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 15:18 -
remuxing mpeg1 audio to mpeg2
By ChaosOrb in forum Newbie / General discussionsReplies: 3Last Post: 9th Sep 2009, 15:25 -
AC3 and mpeg1 audio
By izzykatz in forum Newbie / General discussionsReplies: 6Last Post: 14th Feb 2009, 12:39 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 11:24 -
converting mpeg2/ac3 and avi/ac3 to avi/lambmp3
By corumz in forum Video ConversionReplies: 2Last Post: 17th Sep 2007, 10:32
