The last few DVD's that I have backed up using Rip it for me and DVD shrink appear to be done/completed normally. However, when played back on a Sony player, the scene's seem to jump all over the place. It will play for 5-10 minutes fine, then go to the credits and jump to the middle and then to the end and back to the beginning. Anyone else have this problem? Is there a fix or something I am doing wrong?
I am new here, so I hope I am not breaking any rules by asking this question. If I am, delete the post and notify me by email on file and it will not happen again.![]()
Welcome to the forum.
Your question is quite common.
You probably have a disc with a sneaky copy protection on it. Let me guess, a Sony or Disney release? Wall-E, for example, was similar.
The usual answer is to try the latest DVDFabHDDecrypter (free). It gets updated from time to time to deal with new protections.
If it were me, I'd use full disc mode (fab sometimes gives odd results in movie mode). Then open the rip in DVDShrink, if it doesn't complain, it probably okay.
If you name the specific movie(s), someone else could likely give advice or relate what works. Good luck.
Pull! Bang! Darn! -
Thanks for your response. One movie is Transformers: Revenge of the Fallen and another is The Proposal. I've had a few others. I know 2 of them were disney.
All relatively or very recent. You are using tools that haven't been updated in several years on discs that have much newer copy protection.
As recommended above, get the free DVDFab HD Decrypter and rip with that instead.
Oh, and welcome to 2009
Read my blog here.
Thanks for your help, guys. I downloaded it but haven't tried it yet. I'll repost if I have problems.
Why are my authored dvd movies jumping from one scene to another?
By KJ2009 in forum Authoring (DVD)Replies: 1Last Post: 26th Feb 2010, 03:19 -
Gui dvd author-jumping movie in fast motion scenes due to high video bitrat
By extent in forum Authoring (DVD)Replies: 8Last Post: 19th Feb 2009, 08:30 -
Convert DVD to JPG sequence by any second interval?
By omega_weapon in forum EditingReplies: 3Last Post: 29th Jan 2009, 18:01 -
Jumping Text on Motion Menu in DVD Lab Pro 2
By christopheramos in forum Authoring (DVD)Replies: 0Last Post: 21st May 2008, 08:32 -
burned DVD keeps jumping and freezing?
By ssaamm in forum DVD & Blu-ray WritersReplies: 7Last Post: 24th Oct 2007, 10:46
