Is there any kind of software out there that can change the background of your videos.
For eg:
Let's say i recorded myself on video, playing the guitar in my room....and i wanted to make it look like i was in the middle of the desert and there was a big Egyptian pyramid in the background instead of my plane white wall. Is there a software that could transpose...somehow...a different background into your video?
I have no idea about this kind of stuff.....i'm familiar with the Hollywood CGI and Blue background visualization...but is there a software or program for the home studio novice?
Thanks.![]()
Results 1 to 12 of 12
In sony vegas there is a feature called "difference" that compares the difference between pictures, so if you were the only difference it would eleminate everything, but you. Else you could hang a green sheet on your wall and chromakey the sheet out and replace it with something else..
A bit of background about chroma keying: http://en.wikipedia.org/wiki/Chroma_key
Most editing tools allow for basic keying. There is even the free cinegobs keyer, which is quite good.
However these all depend on you having planned for this ahead of time, and having shot the video of you in front of a green or blue screen , with proper lighting etc.
While you can sometimes extract something after the fact using rotoscoping or difference keying, it is generally a lot harder to do, takes a lot more effort, and produces lower quality results.Read my blog here.
I think lowell meant that "difference" means chromakeying...You'll never be the only difference without a greenscreen. This is why greenscreens are so popular and heavily used. You can be in Egypt in one shot and Hoboken the next. You can be on a large virtual set. But the short answer to your question is, unfortunatley, no. You'll need to shoot in greenscreen first...then switch the backgrounds in post. The only alternative I can think of is cutting yourself out frame by frame...(unfortunately, all frames would turn out slightly different)...and then switch backgrounds to whatever. But at 30 frames per second, this obviously would be a huge time-consuming task for even a few seconds.
Or you can rotoscope (i.e. draw mattes for every frame).
http://www.voidix.com/Rotoscope.htmlRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
zoobie, there is a function in Sony Vegas called "difference" that makes comparisons from one picture to another without chromakeying, simply eliminating everything but the differences bewteen the images. So if I took a picture from in front of my house and another with me in front of it "difference" would remove eveything but me as I were the the only thing different.
It is rare that difference gets a clean separation but it certainly helps with manual matte creation. Even a small lighting difference (e.g. a cloud filtering the sun) will ruin a difference matte. Green screen chromakey is much more reliable.Originally Posted by lowellriggsiamRecommends: Kiva.org - Loans that change lives.
I took a peek at difference masking. The methodology makes brain surgery look easy. The tutorial also tells how to fix bad spots where the separation doesn't quite work. Too bad it can't be simplified...I may be tempted to mess with it.
http://www.sundancemediagroup.com/articles/dayvids/difference_masking_in_sony_vegas.htm
I'm going into a video studio with talent this winter to goof with their green screen. The only thing I don't like is that it usually cuts off their legs because they don't want anyone walking on it. -
zoobie, what you're hoping for is a seamless cyc with curved floor/corners for that infinite horizon look, all painted and lighted for chromakey (green, blue, etc). Most times these aren't painted, they're off-white.
Difference mattes can work if you have more controls over Threshold, Bleed, Choke, etc., but the only one I know of that have used successfully is in AfterEffects (Production Bundle version). Difficult though it is, chromakey is still easier to create successfully than Difference mattes.
What you're talking about is Compositing.
Other ways of separating: Luma Keying with a black background, Choked down garbage mattes with some (stupid looking) effect to blend it into the background (a past co-worker of mine saw this done once and then forever after, that was his way of doing it-UGH!), Manually-drawn masks (lots of time-intensive labor!), shooting (ahead of time) with a Z-cam, which has infrared laser or ultrasonic ranging and creates a 3D model where you can choose foreground vs. middle ground vs. background items.
Scott -
At this point, I'm just looking for a studio big enough for the talent to run around in...which is the fun part.
Seems you need a bunch of room for the camera to be backed away from the green screen for those crazy wide-angle shots
PS - You know, I just read the OP's post again. If your "plane white wall" is pretty much evenly lit, you could just key that out with software.
PSS - I see where Tubetape.com has become an advertiser here at VH...They've got some good stuff...like that green screen costume with hood...with better prices than most
Videos with black backgrounds
By tiedie in forum Video ConversionReplies: 5Last Post: 6th Aug 2009, 19:01 -
HD Animated Backgrounds etc
By jamesbustar in forum EditingReplies: 1Last Post: 7th Apr 2009, 08:31 -
dvd menu backgrounds..
By kanithan in forum Newbie / General discussionsReplies: 8Last Post: 10th May 2008, 09:25 -
backgrounds in XP Home
By snafubaby in forum Newbie / General discussionsReplies: 3Last Post: 6th Dec 2007, 04:04 -
Backgrounds
By boggle in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 2nd Jul 2007, 13:35
