I am running windows XP sp3. My card reader reconizes the regular cf,sd cards, but DOES not reconize when i put a sdHC(hi capcity) card in. what do i have to do??
Please check http://support.microsoft.com/kb/934428 ... 4 gigabyte barrier limitation patch for SDHC
Did you use this for the same problem I'm refering to??? I just want to try & understand that this won't cause any other problems.. Thanks
In my case it was NOT Windows....it was my card reader. I had to buy a new one.....one that recognizes sdhc cards.
Originally Posted by Bjs--
1: Check card reader supports sdhc, if not replace, if so check with manufacturer for update
2: Sp3 was installed as an update ... from toshiba support forum
1. Uninstall SP3, and reboot into SP2.
2. Copy the following files from c:\windows\system32\drivers to somewhere safe: sdbus.sys, sffdisk.sys, sffp_sd.sys. I put them on my desktop. They should all be version 6.0.4061.1
3. Install SP3, and reboot.
4. Shutdown, and restart using F8 to go into Safe Mode.
5. Log in as Administrator (or another account with admin rights)
6. In C:\windows\system32\drivers rename each of sdbus.sys, sffdisk.sys and sffp_sd.sys.to have a .old extension.
7. Copy the files you saved in step 2 to c:\windows\systems32\drivers
8. Shutdown and restart normally. -
If you have SP3 installed then it has to be the reader, go to www.newegg.com and buy a new one. I bought a Rosewill SDHC reader for $5USD.
JVC GY HM100 + Transcend SDHC cards
By Krisse in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 9th Jul 2011, 06:32 -
Class 4 and Class 6 SDHC cards with Canon HF200
By eteune in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 25th Dec 2009, 14:10 -
DV Tape vs. SDHC for a HD camera
By Cazz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 49Last Post: 3rd Jun 2009, 15:33 -
Programs won't reconize video file ?!
By Beastly Swagger in forum Video ConversionReplies: 1Last Post: 26th Jan 2009, 17:42 -
SD/SDHC Memory Card
By bluemoss in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 29th Nov 2007, 11:28
