I used Orbit to download some streaming video. The video downloaded as 10 segments of mp4, and now I want to join them together. I do not want to convert or encode the video. I just want to combine the parts into one video. Below is the Gspot of the part1 of the video. Media Player Classic plays all 10 of these videos perfectly.
I tried using AVIdemux 2.4 to combine the first 2 parts (took just a few seconds). (See screenshot 2). I tried all options that are circled in red, but the combined video always stuttered or froze in Media Player Classic. ( I also tried Video> Mpeg4 AVC x264 but that started to recode, long time). Then I tried Yamb to join the first 2 parts. It seemed to quickly join ( the file size was equal to the sum of the 2 parts). However, when I played the joined file, the play time was equal to just the first part, and there wasn't any second part.
Here is the Yamb log:
[22:43:19] : Yamb 2.1.0.0 beta 2 started !!!
[22:43:19] : OS type detection...Windows XP Professional x86 (version 5.1, Build 2600 : Service Pack 2)
[22:43:19] : MP4Box found... C:\Documents and Settings\VIC\Application Data\Yamb\MP4Box.exe
[22:43:19] : EAC3to found...c:\documents and settings\vic\application data\yamb\eac3to\eac3to.exe
[22:43:47] : 1.mp4 loaded.
[22:43:50] : 2.mp4 loaded.
[22:43:59] : Creation of 1.3gp...
[22:43:59] : Command Line used for Creation : "C:\Documents and Settings\VIC\Application Data\Yamb\MP4Box.exe" -add "C:\Downloads\1.mp4#1:fps=25.000" -add "C:\Downloads\1.mp4#2br" -add "C:\Downloads\2.mp4#1:fps=25.000" -add "C:\Downloads\2.mp4#2
br" -itags tool="Yamb 2.1.0.0 [http://yamb.unite-video.com]" -3gp -new "C:\Downloads\1.3gp"
[22:43:59] : File saved in C:\Downloads\
[22:43:59] : Importing ISO File...
[22:44:02] : Importing ISO File...
[22:44:06] : Importing ISO File...
[22:44:07] : File Writing...
[22:44:16] : Creation complete.
[22:44:16] : Total Time Elapsed...17 secs
[22:44:34] : Yamb 2.1.0.0 beta 2 closed.
Looking at the log, I don't see any reason why the joined file didn't contain both parts.
If someone could take a look at these 2 files and see if you could join them, I would really appreciate that. If I could join these 2 files, then I probably could join all 10 parts.
Link to 2 files in a rar:
http://rapidshare.com/files/316210556/New.rar
It looks like yamb makes two video tracks for the mp4.
See https://www.videohelp.com/forum/archive/joining-serveral-files-with-mp4box-results-in-2...s-t369220.html . Same problem. No solution though... -
I found this software, Boilsoft Video Joiner 5.32 (see screenshot) that seems to work (join without encoding and play properly with Media Player Classic). I had a previous version of this software, which would not accept these mp4 files. However, this software is not free.
This software is widely available on the web.
My question is: Is there a free software that will join these mp4 files? It seems to me that if there is pay software, there should also be free software.* Direct stream clone, without re-encode
* Support join AVI, DivX, Xvid
* Support join MPEG-1, MPEG-2, VOB
* Support join ASF, WMV, WMA
* Support join 3GP(.3gp, .3g2) video files
* Support join MP4 (.mp4, .m4a, .m4v) files
* Join video files as many as you want
* Scramble and rearrange the video clips in the sequence that you exactly desire.
* Very User-friendly interface.
Hey,
So I was having the same issues when I came across this thread. I did a lot of searching and found over and over again people saying to YAMB. Since the 2.1 beta wasn't working and I saw some success stories with version 1.6, I went back and tried 1.6. Worked GREAT!
So give Yamb 1.6 a try and see if that doesn't do the trick for ya.
Hope this helps!
Jimmy -
PROBLEM SOLVED. Yes it does help. Confirmed that free software Yamb 1.6 works to join the posted mp4 files http://rapidshare.com/files/316210556/New.rar
(Yamb 2.1beta does not work).
Joining MP4 files from youtube
By eng3 in forum Video ConversionReplies: 0Last Post: 22nd Nov 2010, 15:00 -
Joining MP4 files
By Xpenguin17 in forum EditingReplies: 2Last Post: 22nd Jul 2010, 07:23 -
MP4 Joining Problem.
By nicolasonline in forum EditingReplies: 3Last Post: 7th Jun 2010, 15:06 -
joining mp4 files
By slgorin in forum EditingReplies: 3Last Post: 3rd Sep 2009, 18:47 -
Joining two MP4 files
By biomech in forum EditingReplies: 1Last Post: 14th Sep 2008, 19:16
