I have this same problem but i don't have a samsung tv. I'm using a Logik L22LDVB21, i have it set up as my second monitor, i've tried with the hdmi cable on it's own, and with a DVI adapter on the end of it, neither fixed it. The text is just blury, i've changed the sharpness to 0, but the one thing i keep seeing people suggest is to change the channel name to PC. But i cannot find how to do this :/
Any ideas? Thanks in advance!
Results 31 to 44 of 44
That is just a quirk in the Samsung user interface. It won't apply to Logik.
Understand that for best text clarity the desktop, display card settings and monitor (native resolution) must be the same. Since your monitor is native 1920x1080, the display card should be sending 1920x1080 and the 2nd desktop should be 1920x1080. Blurring occurs when either the display card or monitor try to rescale.
The goal is 1:1 pixel mapping through the full chain to the monitor.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Hi edDV,
By looking at SoLiD's post, i think that using hdmi to DVI adapter won't solve my problem either. The reason being the signal is still sent by hdmi cable and the adapter just re-arranges the pins. Right? -
Also just made an account to say thanks! HDMI -> PC rename worked like a charm.
I also just made an account to say thanks for the name editing fix (although my tv has a DVI PC option which is what I use). I was about to return the dvi->hdmi cable I just bought and give up on hooking up computers to tv's via hdmi forever. I do see in my tv's manual under Edit Name that it tells you to do this for pc inputs, but it sounds more like an optional thing than something you have to do to get it to work correctly. It really should be in the Connecting To A PC section and written with more emphasis.
I got an insignia 32" to use for a monitor. Same problem with the unclear text. Screwed around with monitor settings, went into the Catalyst on windows and messed with settings, tried all HDMI ports, renamed the input to PC,...nada. Then I got an HDI to HDMI adapter and that did the trick. I'm frustrated with this solution because I need to run some other wires for the audio. Also...it just doesn't make sense to me. My monitor doesn't have this AV Mode thing to try...but at least the screen looks great.
BINGO! Thank you!
Just upgraded to a new laptop. Although it has the same Intel HD 3000 integrated graphics as the old one, the new laptop produces blurred images on my Samsung 22" monitor through the VGA port -- 1-pixel lines are smudged into 2 pixels. A partial fix was changing the scan rate from 60 Hz to 70 Hz in the Intel graphics menu. But the VGA image was still less sharp than the old laptop, a big disappointment.
Switching over to the HDMI connection, the image had different (but equally objectionable) artifacts due to overscan correction. As you wrote, it was simply a matter of redefining the HDMI source as a PC -- display transformed instantly!
Samsung's manual for the monitor doesn't offer a clue about this obvious troubleshooting issue that plenty of users will encounter when connecting a PC to the monitor with an HDMI cable.
I registered to say 'thanks' and to help bump this post in search ratings so others can find it. Amazing how a task as simple as connecting a PC to a monitor turns into an electronics hobbyist project. At least I didn't need a soldering iron to complete it ... -
Hi everyone,
I also found a solution in the "Name" property of the input for my TA550, but sadly it was a temporary one. When i plug my pc into HDMI1 the picture is nice and clear, but the problem is most of the settings are disabled on my monitor. The single most annoying one is the auto-dimming which i just hate when playing any game with dark areas. If i use the second HDMI-port all the options are available, but the image looks like crap, as mentioned above text is blurry and the colors are off. The namechange doesn't work with the second port, so I was wondering if anyone has come up with any other solution? Having to choose between a better image with auto-dimming and a worse image without it is driving me nuts. -
The issue here is that you have a tv that acts as a monitor rather than a dedicated monitor.
You appears to have one hdmi port that is dedicated for PC use and that gives the clear picture whereas the other is really intended just for tv use.
If your graphics card has dual hdmi output you could connect both to the tv and switch the output on the PC when you need to. -
I see. Didn't even realise that it makes a difference if it's a dedicated monitor or a tv, but I guess it makes sense.
Seems like the only option really is to just switch between the two, which of course is only a minor inconvenience. Still, can't help but wonder why on earth the settings for so much stuff are locked when in "pc-mode". Other stuff I don't even mind but this automatic dimming crap is just unbelievable.
Anyways, thanks for quick reply -
Sorry I messed up my htaccess file. Thanks for pointing that out. Here's the link: http://mobilewebtechs.com/blog.php
Text Fuzzy Blurry with HDMI cable
By andriask in forum DVB / IPTVReplies: 27Last Post: 18th Apr 2014, 06:40 -
Blurry video in monitor of Premier Pro CS5
By oldtimefiddler in forum Newbie / General discussionsReplies: 10Last Post: 21st Jan 2012, 00:25 -
Making an Audio CD with ACCURATE text
By qwertyuiopasdfghjklzxcvbn in forum AudioReplies: 3Last Post: 10th Apr 2011, 18:47 -
Text in video - Good with WinAVI, blurry with Winff (.flv to mpeg/DVD)
By Paker in forum Video ConversionReplies: 25Last Post: 13th Sep 2009, 12:07 -
Putting text over a video (making a compilation RATM DVD)
By Salva Veritate in forum EditingReplies: 4Last Post: 1st Sep 2007, 13:52
