So just transferred 1 hour of video from a MiniDV to AVI using Microsoft Import in Windows Vista. Quality was not good. Very jagged edges and lots of jitter. Tried using Adobe Elements 3 to do teh transfer and video quality was good again. SO my question now is, what is the best way to output that miniDV footage so that it plays nicely on a 1080P LCD. Should I just output at SD or can I try some HD + keep aspect ratio with letterbox? Any tips would be great.
You should be transfering from the camcorder into a DV AVI file. That simply puts the DV data that's on the tape into an AVI file -- there is no loss of quality that way. Then most players will automatically deinterlace on playback on the computer.
If you want to try conversion to HD then WinX HD Video Converter is being given away till the 16th of this month ... costing you nothing and if your not happy with end results then you decide if you want to keep it or uninstall it
Generally, you won't gain anything by converting standard definition DV to HD frame sizes. Especially with interlaced video.
If by "1080p LCD" you mean an LCD-TV, normal output would be DVD spec interlace MPeg2 (high bitrate) or uncompressed 480i/576i via HDMI or analog component. The upscale would be handled by hardware in the media player or inside the HDTV. H.264 is another option but it would be suboptimal for interlace video.Originally Posted by bowmah
As Jagabo said, there is little advantage to software upscale. It is normally done when including SD source in an HD edit project.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
HDTV Audio output is too low. Help
By daustemd1551 in forum AudioReplies: 1Last Post: 1st Nov 2009, 21:08 -
Looking for new minidv camcorder. Panasonic miniDV or other?
By latin trident in forum Newbie / General discussionsReplies: 7Last Post: 22nd Oct 2008, 16:54 -
miniDV to hard drive to miniDV while preserving time and date?
By vid83 in forum Newbie / General discussionsReplies: 1Last Post: 10th Dec 2007, 22:46 -
Just bought NVidia GS7300 card with HDTV/S-Video output capability, but
By tzm in forum DVB / IPTVReplies: 6Last Post: 27th Jun 2007, 12:43 -
Enigmavision HDTV - HDTV viewer software for ATSC TV tuner cards.
By gc04 in forum Latest Video NewsReplies: 9Last Post: 7th May 2007, 01:32
