    Nov 2009
    Australia
    I have a couple of these files. They do not play on the Windows Media Player but do play on VLC. I have a Noontec TV media streamer (which I only purchased because it said it played MKV files) but there is no sound when I play on thru this.
    I tried to convert the MKV file to other formats (eg mp4) and I could play these on, say, the Windoes Media Player (and the Noontech) but the video was anything but smooth.
    Does anybody know of anything I can do to play the MKV file through the Noontech (or convert it without losing its original quality) ?
    Amyway, for the record, there is zero support for the Noontec and I regret purchasing it
  2. Member midders's Avatar
    Sep 2008
    Use MediaInfo to identify the tracks in your MKV file, then MKVToolnix to demux:
    MKVExtract.exe tracks inputfile.mkv 1:video.??? 2:audio.???
    Then convert your audio file to a format that is compatible with your Noontec (check the documentation or pick something universally compatible). Software for the audio conversion varies; check the tools section.
    Once you've converted the sound mux the original video and new sound track back into an mkv container using MKVmerge.
    Nov 2009
    Australia
    Many thanks mate, will give it a go!
