Hi.
If I have now recordin and edit my movie that is in 1080 HD and I like to save it on the harddrive.
What do I have to do to save it as good as possible?
It is alot to choose when it time to render.
When I looking after a tutorial in Youtube I only find how to save it in WMV to upload it to the youtube but
I'm not going save it on the internet. I have see and download some example clip and have see they are in very very good quality but still
very small. And when I use Mediainfo it don't say so much more then what codec it use and that and I know it is not any WMV.
Do anyone have any tutorial to help me?
You could save it as a lossless format e.g. lagarith or huffyuv , but the filesize will be huge (still about 1/2 size as uncompressed). This is "as good as possible"
If you use other forms of lossy compression, there will be varying degrees of quality loss
Youtube re-encodes everything with a low bitrate, so the file you upload is not the same as you download -
mm yes lossless is good when I have to edit and that but when everthing is finnish and it is time to create the movie I like to have a good quality.
When I did recording in DV I save it in Xvid in a good quality but now I like to save it HDV in better quality like AVC.
/Update
A little update, I think I have found it and I have to now find out what is the best bitrate to use.
Is Sony Vegas Movie Studio HD Platinum 10 a good editing software?
By vid83 in forum EditingReplies: 8Last Post: 4th Feb 2011, 07:02 -
How to save subclip as original video (Sony Vegas)?
By jiopi in forum EditingReplies: 1Last Post: 12th Jan 2011, 16:07 -
Save Xvid from Sony Vegas Movie Studio
By Cazz in forum EditingReplies: 12Last Post: 29th Jun 2010, 11:50 -
Can I save a project "template" with Sony Vegas?
By sdsumike619 in forum EditingReplies: 2Last Post: 27th Jul 2009, 21:33 -
Need a H-Quality AVI to MPG BATCH converter - As good as Sony Vegas
By Ratman in forum Video ConversionReplies: 3Last Post: 18th Oct 2007, 12:42
