Page 2 of 2
FirstFirst 1 2
Results 31 to 32 of 32
    Oct 2008
    Hey budz (or just anyone), for the Thermalright Ultra 120 you suggested, do you think a pull/push set up is good? And if so, is there a recommended second fan I should go with? I don't know how loud different levels of dB's are but should I go with http://www.newegg.com/Product/Product.aspx?Item=N82E16835185060&cm_re=120mm_fan-_-35-1...-060-_-Product
  2. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    ^^^SCYTHE Slipstream fans don't have good static pressure and they are only good to use as case fans. Get the SCYTHE S-FLEX "F" or "G" series fans as they're the best to use for cpu fans.
    SCYTHE S-FLEX "G", $14.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835185065
    SCYTHE S-FLEX "F", $16.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835185006
    I use those S-FLEX fans on my CM Hyper 212 & CM GEMINII S CPU coolers!
