I like to be able to insert moving maps into my videos. For example, if the action moves from Rome to Paris, I would like to show a map of Rome, then zoom out and "fly" to Paris and zoom in.
Maybe even showing a line tracing the route taken!
Google Earth has this facility - you can create a route and store amnd play it.
In GE professional it even allows export of this as a movie.
But the quality is very poor.
Google My maps looks promising - anyone had success with this?
Any other suggestions as to how to do this?
Thanks!
One option is to screen record the movement from Google Earth
I would do it in after effects. It would be harder to do, but you could do things like line tracing (a la Indiana Jones style), rotating, 3d space, camera moves, etc... and would look much better because you can customize it, use custom maps, and export in any quality you want. There are tutorials online for this sort of thing, just use search terms like indiana jones map effect, etc... and there are dozens out there...
e.g. for the line tracing
http://ae.tutsplus.com/tutorials/motion-graphics/map-your-destination-in-ae/
http://www.youtube.com/watch?v=zxg7lnFjtdE
I'm sure there are a few others. The zoom in/out is pretty easy to do in AE, because you have a 3d camera that can move independently of the assets -
Thanks for that!Originally Posted by poisondeathray
AE maybe a bit out side my budget!!
Just found the following:
http://www.videoforums.co.uk/reviews/features/fly-to-your-destination-a34.html
Going to try that as well as your other search suggestion!! -
Google Earth ain't the only game in town. There's also World Wind http://worldwind.arc.nasa.gov/download.html, a free prog from NASA that (iirc) can output a sequence of JPEGs that you can make into a movie clip. They also have maps for the Moon, Mars and Saturn...
Thanks... I have looked at World Wind, but coverage outside USA is very poor, and load time for images is very slow.Originally Posted by olyteddy
Maybe if my trip was extraterrestrial....!
Thanks for that. Bit complicated for me. I find using Pinnacle Studio Plus challenging!Originally Posted by El Heggunte
But you have a point... in the absence of a slick solution, pan & zoom (within Studio Plus) using still images is probably where I'll end up!!
placing a moving picture into another video
By tomchook in forum EditingReplies: 4Last Post: 9th Oct 2015, 18:25 -
Removing moving object from a video
By Lucky Starr in forum EditingReplies: 4Last Post: 31st Mar 2012, 15:39 -
How do you Put a picture in to a moving video?
By ThePumpkinKingJuggalo in forum Newbie / General discussionsReplies: 4Last Post: 11th Sep 2010, 00:10 -
LaCie La Cinema;I removed the maps:(
By saywhot in forum Newbie / General discussionsReplies: 0Last Post: 14th Aug 2010, 16:29 -
Google Maps
By Anurag in forum ComputerReplies: 4Last Post: 12th Sep 2009, 00:21
Not "easy" nor "intuitive", but it works, and is free.
