I found https://forum.videohelp.com/topic349013.html by google.
In my case, i have an analog tv (i think 7 years old), wit pixel plus technologie and digital correction build in the menu.
For this moment i have my desktop connected with the tv.
The manufacturer (asus) delivered a tv card with the mainboard, and the connection is svid.
I have a acceptable picture on my tv, only in black and white.
But that limitation is discribed in the manual of my computer.
I concider to buy an adapter as mentioned in the topic i found.
-What do you think i should do?
-Will the picture on my tv better, or worse with color?
VGA to TV cables don't convert VGA signals, they simply route pins from the VGA connector to video cables. The graphics cards must be designed specifically to support TV output on those previously unused pins. Those pins are no longer unused on VGA ports so cards that support this haven't be sold for many years.
Can I interface my VGA monitor through a HDMI-DVI-D cable via DVI-D to VGA?
By vinny88 in forum Authoring (DVD)Replies: 4Last Post: 14th Oct 2011, 09:31 -
Portable PAL analog (yes, analog!) television set
By stuey123usa in forum Capturing and VCRReplies: 0Last Post: 22nd Jun 2009, 20:23 -
Audio/Video jack - is this a headphone jack?
By OM2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 26th May 2009, 17:10 -
PC VGA to VGA on LG 42" Plasma
By Squirralien in forum Media Center PC / MediaCentersReplies: 3Last Post: 8th Nov 2008, 21:43 -
laptop with only VGA to VGA-less HDTV
By liiam in forum DVB / IPTVReplies: 0Last Post: 16th Oct 2008, 15:16
