I have an AVI that has DTS 5.1 audio - I want to convert that audio... how do I do it? (any format will do just my TV wont decode DTS) - pref AC3 5.1 but anything just to get it done
thanks
Extract the dts with virtualdubmod, under streams->Stream list->demux.
Convert the dts to ac3 using eac3to.
Mux back the new ac3 to the avi using virtualdubmod or avimuxgui.
Or maybe it works directly with xvid4psp, open avi, choose format avi, under video choose copy and under audio choose ac3. Save. But I'm not sure how it handles the dts to ac3 conversion. -
i cant get avimuxgui to run (im on Windows 7)
also heres the log from aec3to and it doesnt look good
any ideas on how to get avimuxgui to work?Decoding with libav/ffmpeg...
Remapping channels...
Encoding AC3 <640kbps> with libAften...
Creating file "D:\LOTR AC3.ac3"...
Clipping detected, a 2nd pass will be necessary. <WARNING>
This track is not clean. <WARNING>
The last DTS frame is incomplete and thus gets skipped. <WARNING>
Starting 2nd pass...
eac3to processing took 27 minutes, 4 seconds.
Done.
cheers -
thanks Baldrick - ive done a quick test and its working - still keeps the DTS track aswell but my TV still plays the AC3 track - EXCELLENT
- much appreciated
remux from m2ts to m4v/mp4 and remove scan type MBAFF
By jlally in forum Video ConversionReplies: 9Last Post: 18th Apr 2012, 05:01 -
MKV files with Audio in DTS need to convert audio to AC3
By THEHNIC in forum AudioReplies: 5Last Post: 3rd Jun 2011, 09:17 -
Automate remux and remove junk from avi files
By jorb in forum Video ConversionReplies: 1Last Post: 12th Dec 2009, 14:45 -
How to convert AVI with DTS audio to DVD
By Jean in forum Video ConversionReplies: 6Last Post: 24th Aug 2007, 02:25 -
How to convert DTS audio to AC3?
By Henderson in forum AudioReplies: 1Last Post: 26th Jul 2007, 18:33
