hi
if my dvd player said it can play mpeg4, does it means it can play video file with .mp4 extension ?
No. Usually just avi with xvid/divx.
AND PLEASE use a better subject. I changed it it this time. -
oic , therefore it cannot play mp4 with xvid ? Thanks for previously reply
Why does the dvd player said it can play mpeg4 while it can only play avi with xvid. really very confusing. So what is mpeg4 since it is not mp4.Originally Posted by c1steady
i read somewhere in this forum that mpeg4 is actually mp4 also. am i right ? -
MP4 is a container (like AVI, MKV, MPG). MPEG 4 is a video compression specification (among other things). It encompasses two main specs: part 2 (ASP, Xvid, Divx, etc.), and part 10 (AVC, h.264, etc.).
What most DVD players mean when they say they support MPEG 4 is that they support MPEG 4 part 2 encoded video in an AVI container. Most do not support the MP4 container. And when they do they usually only support MPEG 4 part 2 in that container, not MPEG 4 part 10. -
This is quite correct. It's yet another example of the industry trying to be helpful (and failing) or deliberately misleading with descriptions that can be misunderstood. Another example is the "1080 compatible" description that was used on some 720p HDTVs that caused consumers to think that they were buying a 1080p TV when in fact it is just a deliberately confusing term that means that the TV will downscale 1080i/p input to the TV's native resolution (720p or slightly bigger depending on the model).Originally Posted by jagabo
DVD player with MPEG4 support cannot recognize MP4
By videohalp in forum DVD & Blu-ray PlayersReplies: 2Last Post: 29th Dec 2011, 08:42 -
loop mp4 or avi locally so will play on mp4 player - ?
By marinebc11 in forum Video ConversionReplies: 3Last Post: 3rd Oct 2010, 21:24 -
MP4 cannot for the life of me play it on my dvd player
By skateonice in forum Newbie / General discussionsReplies: 3Last Post: 17th Apr 2010, 10:51 -
Play mp4's on portable DVD player
By David_UK in forum Video ConversionReplies: 4Last Post: 20th Mar 2009, 13:29 -
confused with mp4, won't play, can I convert?
By frankg in forum Newbie / General discussionsReplies: 1Last Post: 5th Jul 2007, 08:18
