I'm trying a logo removal filter in virtualdub. The x-logo filter. I'm really amazed at the results, although this is a simple white transparent logo.
The problem is the logo appears over multiple frame sequences. A few seconds a fifth of the way through the film and then a few seconds a third of the way, again at the mid point, etc.
But the x-logo config panel doesn't have an option for multiple in/out points. Just one in point/ one out point.
Is there a way around this?
I'd use avisynth if I could find a tut on a script for it.
Results 1 to 21 of 21
Thanks for the suggestion, but I can't get that one to work. I open multiple instances of the filter and do the settings, but virtualdub won't let me run them.
So, now I'm looking into an avisynth script, but the only examples I've found use the trim function. Like this:
clip=AVISource("pb_221.avi",false)
clip.Trim(0,19) ++\
clip.Trim(20,0).xlogo("logo221_x_540_y_300_2.bmp", X=540, Y=300, alpha=0)
I, don't know. Maybe I'm reading this wrong. Do I have it right that the first trim segments frames 0-19 without applying a filter? and then the second trim is applying the filter to frames 20 till the end. But it adds the two segments back together? Is that what it's doing?
So, if I had a 90 minute video I'd use something like:
clip.Trim(0,12776) ++\
clip.Trim(12777,13798).xlogo("logo221_x_540_y_300_ 2.bmp", X=540, Y=300, alpha=0) ++\
clip.Trim(13799,48419) ++\
clip.Trim(48420,49445).xlogo("logo221_x_540_y_300_ 2.bmp", X=540, Y=300, alpha=0) ++\
All the way till the end of the movie? -
If you have a lot of different sections, you might find it easier to use the ReplaceFramesSimple function:
Code:clip.ReplaceFramesSimple(clip.xlogo("logo221_x_540_y_300_2.bmp", X=540, Y=300, alpha=0), \ mappings = "[12777 13798] [48420 49445] ... ")
If not using ReplaceFramesSimple, it would still be better to rewrite as
Code:clip2 = clip.xlogo("logo221_x_540_y_300_2.bmp", X=540, Y=300, alpha=0) clip.Trim(0,12776) ++\ clip2.Trim(12777,13798) ++\ clip.Trim(13799,48419) ++\ clip2.Trim(48420,49445) ++\ ...
Okay. Well, I'm using this script:
AVISource=("F:\clipfolder\clip.avi")
Trim(0,12776) +\
Trim(12777,13798).xlogo("C:\bg2_x_489_y-426_0.bmp",X=489,y=426,alpha=20) +\
Trim(13799,48419) +\
Trim(48420,49445).xlogo("C:\bg2_x_489_y-426_0.bmp",X=489,y=426,alpha=20) +\
Trim(49446,74999) +\
Trim(75000,76021).xlogo("C:\bg2_x_489_y-426_0.bmp",X=489,y=426,alpha=20) +\
Trim(76022,103692) +\
Trim(103693,104714).xlogo("C:\bg2_x_489_y-426_0.bmp",X=489,y=426,alpha=20) +\
Trim(104715,128876) +\
Trim(128877,129899).xlogo("C:\bg2_x_489_y-426_0.bmp",X=489,y=426,alpha=20) +\
Trim(129900,154800) +\
Trim(154801,155822).xlogo("C:\bg2_x_489_y-426_0.bmp",X=489,y=426,alpha=20) +\
Trim(155823,165476) +\
Trim(165477,166207).xlogo("C:\bg2_x_489_y-426_0.bmp",X=489,y=426,alpha=20) +\
Trim(166208,0)
But I get an error saying that there is an Invalid Argument to the Trim function in the last line.
Gavino: I already had this script written out before I saw your post. I might give that a try, but I'd like to know what is wrong with my last line. -
Originally Posted by manono
I also tried giving it the last actual frame number.
Thanks for the suggestions though. I should have mentioned that earlier. -
Good eyes. I completely missed that. I can blame it on the error message which isn't always very helpful and sometimes (as in this case) downright misleading.
In this case, the error message can easily throw you off the scent, since it seems to point to the wrong place.
But AVISource=("F:\clipfolder\clip.avi") is a valid statement (assigning a string to the variable AVISource) so Avisynth cannot know that you meant something else.
The result is that all the Trim's are seen as invalid because no input clip has been defined. However, it gets reported as being on the last line since the whole series of Trims is just one statement continued over many lines.
Knowing that "Invalid arguments" often comes from an undefined input clip led me to look at the previous line where the real error was. -
I don't do "script".
http://www.youtube.com/watch?v=2MWoVY9mYbk -
Code:AVISource("F:\clipfolder\clip.avi") src = last filtered = xlogo("C:\bg2_x_489_y-426_0.bmp",X=489,y=426,alpha=20) ReplaceFramesSimple(src, filtered, mappings= \ "[12777 13798] [48420 49445] [75000 76021] [103693 104714] [128877 129899] [154801 155822] [165477 166207]")
I use AvsP to step through a video, and use its bookmark (control-B) to mark the transitions, then save these to a file, paste them into a template.
I also always put the video, the image file and the script in the same folder, then I don't need to specify full paths.
A different folder for each project, which I can then archive away as a unit. -
Originally Posted by Gavino
So, I went back to the code. After I posted last night I decided to try the ReplaceFramesSimple. Of course, when it came to the AVISource line, I just copied and pasted from the other script. So, not surprisingly, I got the same error with ReplaceFramesSimple.
So, when I went back I just decided to use the ReplaceFramesSimple because it is a lot less tedious. But what happens is VirtualDub crashes. Whenever I try to scrub the timeline while the script is loaded it crashes. An access violation. So, I tried to go ahead and save the AVI anyway. And it crashed right at the first frame that needed X-logo.
So, I went back to my other script and fixed it. But, it crashes the exact same way; with an access violation. The error message reads:
"out of bounds memory access (access violation) occurred in VirtualDub... reading address 00000008"
Sometimes the address was 00000010, but the thing is it crashes at the first frame the filter is applied to.
So, this is a pain. I checked to see that the film itself ran okay. No problem there. I can scrub the entire length of the film. Back and forth. No problem.
Last night when the scripts wouldn't work, I tried DeLogo. But the preliminary results didn't look so great.
So, tonight I'll probably look for another logo removal filter, I think there's another one, just can't remember the name.
But, X-logo gives me great results. At least it looks good on the previews I've looked at.
I do have a crash dump from VirtualDub. I don't know if anyone can make sense of it or not. I can't. But, I'll post it just in case someone can. This dump was with the Trim script.
=================Crash report==================
VirtualDub crash report -- build 30091 (release)
Disassembly:
004caea0: 53 push ebx
004caea1: 55 push ebp
004caea2: 56 push esi
004caea3: 8bf1 mov esi, ecx
004caea5: 8b8614050000 mov eax, [esi+514]
004caeab: 83e0fe and eax, 0feh
004caeae: 83f802 cmp eax, 02h
004caeb1: 57 push edi
004caeb2: 7524 jnz 004caed8 (VideoSourceAVI::_isKey+38)
004caeb4: 8b5e10 mov ebx, [esi+10h]
004caeb7: 8b4c2414 mov ecx, [esp+14h]
004caebb: 8b6e14 mov ebp, [esi+14h]
004caebe: 8b542418 mov edx, [esp+18h]
004caec2: 6a00 push 00h
004caec4: 2bcb sub ecx, ebx
004caec6: 50 push eax
004caec7: 1bd5 sbb edx, ebp
004caec9: 52 push edx
004caeca: 51 push ecx
004caecb: e8b0690b00 call 00581880 (_alldiv)
004caed0: 8bfa mov edi, edx
004caed2: 03c3 add eax, ebx
004caed4: 13fd adc edi, ebp
004caed6: eb08 jmp 004caee0 (VideoSourceAVI::_isKey+40)
004caed8: 8b7c2418 mov edi, [esp+18h]
004caedc: 8b442414 mov eax, [esp+14h]
004caee0: 8bae0c050000 mov ebp, [esi+50c]
004caee6: 85ed test ebp, ebp
004caee8: 7432 jz 004caf1c (VideoSourceAVI::_isKey+7c)
004caeea: 8b4e10 mov ecx, [esi+10h]
004caeed: 8b5614 mov edx, [esi+14h]
004caef0: 2bc1 sub eax, ecx
004caef2: 1bfa sbb edi, edx
004caef4: 8bc8 mov ecx, eax
004caef6: 83e11f and ecx, 1fh
004caef9: bb01000000 mov ebx, 00000001
004caefe: d3e3 shl ebx, cl
004caf00: 8bd7 mov edx, edi
004caf02: b105 mov cl, 05h
004caf04: e8d7650b00 call 005814e0 (_allshr)
004caf09: 235c8500 and ebx, [ebp+eax*4+00h]
004caf0d: 5f pop edi
004caf0e: f7db neg ebx
004caf10: 1bdb sbb ebx, ebx
004caf12: 5e pop esi
004caf13: f7db neg ebx
004caf15: 5d pop ebp
004caf16: 8ac3 mov al, bl
004caf18: 5b pop ebx
004caf19: c20800 ret 0008
004caf1c: 8b8ec8040000 mov ecx, [esi+4c8]
004caf22: 8b11 mov edx, [ecx]
004caf24: 57 push edi
004caf25: 50 push eax
004caf26: 8b4210 mov eax, [edx+10h] <-- FAULT
004caf29: ffd0 call eax
004caf2b: 5f pop edi
004caf2c: 5e pop esi
004caf2d: 5d pop ebp
004caf2e: 5b pop ebx
004caf2f: c20800 ret 0008
004caf32: cc int 3
004caf33: cc int 3
004caf34: cc int 3
004caf35: cc int 3
004caf36: cc int 3
004caf37: cc int 3
004caf38: cc int 3
004caf39: cc int 3
004caf3a: cc int 3
004caf3b: cc int 3
004caf3c: cc int 3
004caf3d: cc int 3
004caf3e: cc int 3
004caf3f: cc int 3
004caf40: 53 push ebx
004caf41: 56 push esi
004caf42: 8bf1 mov esi, ecx
004caf44: 83beac04000000 cmp dword ptr [esi+4ac], 00h
004caf4b: 57 push edi
004caf4c: 7457 jz 004cafa5 (VideoSourceAVI::nearestKey+65)
004caf4e: 8b5c2414 mov ebx, [esp+14h]
004caf52: 3b5eb4 cmp ebx, [esi-4ch]
004caf55: 7c43 jl 004caf9a (VideoSourceAVI::nearestKey+5a)
004caf57: 8b7c2410 mov edi, [esp+10h]
004caf5b: 7f05 jg 004caf62 (VideoSourceAVI::nearestKey+22)
004caf5d: 3b7eb0 cmp edi, [esi-50h]
004caf60: 7238 jc 004caf9a (VideoSourceAVI::nearestKey+5a)
004caf62: 3b5ebc cmp ebx, [esi-44h]
004caf65: 7f33 jg 004caf9a (VideoSourceAVI::nearestKey+5a)
004caf67: 7c05 jl 004caf6e (VideoSourceAVI::nearestKey+2e)
004caf69: 3b7eb8 cmp edi, [esi-48h]
004caf6c: 732c jnc 004caf9a (VideoSourceAVI::nearestKey+5a)
004caf6e: 8b46a0 mov eax, [esi-60h]
004caf71: 8b5060 mov edx, [eax+60h]
004caf74: 8d4ea0 lea ecx, [esi-60h]
004caf77: 53 push ebx
004caf78: 57 push edi
004caf79: ffd2 call edx
004caf7b: 84c0 test al, al
004caf7d: 740a jz 004caf89 (VideoSourceAVI::nearestKey+49)
004caf7f: 8bc7 mov eax, edi
004caf81: 5f pop edi
004caf82: 5e pop esi
004caf83: 8bd3 mov edx, ebx
004caf85: 5b pop ebx
004caf86: c20800 ret 0008
004caf89: 8b06 mov eax, [esi]
004caf8b: 8b5064 mov edx, [eax+64h]
004caf8e: 53 push ebx
004caf8f: 57 push edi
004caf90: 8bce mov ecx, esi
004caf92: ffd2 call edx
004caf94: 5f pop edi
004caf95: 5e pop esi
004caf96: 5b pop ebx
004caf97: c20800 ret 0008
004caf9a: 5f pop edi
004caf9b: 83c8ff or eax, 0ffh
004caf9e: 5e pop esi
004caf9f: 0b db 0bh
Built on Aegis on Sun Jan 04 12:35:50 2009 using compiler version 1400
Windows 5.1 (Windows XP x86 build 2600) [Service Pack 3]
EAX = 0000989c
EBX = 00000000
ECX = 00c3e2a8
EDX = 00000000
EBP = 00000000
ESI = 00c3f040
EDI = 00000000
ESP = 0012f6dc
EIP = 004caf26
EFLAGS = 00210246
FPUCW = ffff027f
FPUTW = ffffffff
Crash reason: Access Violation
Crash context:
An out-of-bounds memory access (access violation) occurred in module 'VirtualDub'...
...reading address 00000010.
Pointer dumps:
ECX 00c3e2a8: 00000000 0033bedc 00c3d1d8 0206e6d0 00030006 01080144 00000000 000002d0
ESI 00c3f040: 005c7ed8 00000002 00c3d168 00000028 00000000 00000000 000255f0 00000000
ESP 0012f6d8: 00000000 0000989c 00000000 0000989c 00c3f040 0012f798 00000000 004cb3a3
0012f6f8: 0000989c 00000000 0018dd15 00000000 00000000 00c3f0a0 00497299 0000989c
0012f718: 00000000 0000989c 00c3b4d8 00000000 0087b7e4 00000014 00005dc0 000003e9
0012f738: 00000000 00000010 0018dd15 00000000 0018dd15 00000000 0000989c 00000000
Thread call stack:
004caf26: VideoSourceAVI::_isKey()
004cb3a3: VideoSourceAVI::getFrameTypeChar()
00497299: VDProjectUI::GetFrameString()
7e41882a: USER32!GetDC [7e410000+86c7+163]
0044cbdd: VDPositionControlW32::UpdateString()
7e42c228: USER32!DefWindowProcA [7e410000+1c17e+aa]
7e418bd9: USER32!GetWindowThreadProcessId [7e410000+8a80+159]
7e42c23c: USER32!DefWindowProcA [7e410000+1c17e+be]
7e42c1e9: USER32!DefWindowProcA [7e410000+1c17e+6b]
0044e175: VDPositionControlW32::WndProc()
005882a5: __set_flsgetvalue()
00588451: _getptd_noexit()
0058a587: write_string()
0058ae97: _output_l()
0058af16: _output_l()
7e4194be: USER32!GetWindowLongA [7e410000+945d+61]
0044e562: VDPositionControlW32::StaticWndProc()
7e418734: USER32!GetDC [7e410000+86c7+6d]
7e41885a: USER32!GetDC [7e410000+86c7+193]
7e42fd6b: USER32!DrawEdge [7e410000+1fbf6+175]
7e429009: USER32!EndPaint [7e410000+18ffd+c]
0044d2ec: VDPositionControlW32::OnPaint()
0044d5c4: VDPositionControlW32::SetDisplayedPosition()
004962ea: VDProjectUI::OnPositionNotify()
0049abda: VDProjectUI::MainWndProc()
7e419488: USER32!GetWindowLongA [7e410000+945d+2b]
004941e0: VDProjectUI::WndProc()
004a327d: VDUIFrame::StaticWndProc()
7e418816: USER32!GetDC [7e410000+86c7+14f]
7e42927b: USER32!GetParent [7e410000+1910f+16c]
7e42f40b: USER32!SendMessageA [7e410000+1f3c2+49]
0044d49b: VDPositionControlW32::Notify()
004f9d76: VDRoundToInt64()
0044e038: VDPositionControlW32::WndProc()
7e4189cd: USER32!GetWindowLongW [7e410000+88a6+127]
7e42a43b: USER32!PeekMessageA [7e410000+1a340+fb]
7e4196c7: USER32!DispatchMessageA [7e410000+96b8+f]
00481b06: WinMain@16()
005855a8: __tmainCRTStartup()
7c817067: kernel32!RegisterWaitForInputIdle [7c800000+1701e+49]
-- End of report -
Originally Posted by AlanHK
Originally Posted by AlanHK -
Originally Posted by hech54
I have x-logo working in VD now and it's being applied over multiple instances. From what I can see in VD it's looking pretty good. Just a tiny bit of blur.
I don't know why, but I just didn't take your post seriously. And I only clicked on the YouTube link after about the third time I saw your post. I guess I just thought you were being sarcastic.
Anyway, Thanks for that. I'll have to look at that guy's website. -
https://forum.videohelp.com/images/guides/p2020914/logotools.zip -
But, yeah there is also a small smeared area that shows up. It's visibility depends on the colors it overlays.
This logo is just lettering. Almost opaque in some parts and more transparent in other parts.
I'll look into LogoTools and see what that's about.
Thanks. -
That's an interesting feature in VD I would never have known about. -
Looking at other YouTube videos, I saw this one:
http://www.youtube.com/watch?v=96Vm78ig8Og
Here, he is using Adobe Premiere and applying a filter called Region Remove Video Filter.
The only filter by that name that I can find is a virtual dub filter.
Is it possible to use a virtual dub filter in Adobe Premiere?
VirtualDub - removing logo off a not-black background
By LukeGuldan in forum EditingReplies: 2Last Post: 20th Nov 2009, 20:31 -
Saving multiple AVIs from 1 AVI by virtualdub script
By DveD in forum EditingReplies: 1Last Post: 16th Oct 2009, 08:47 -
How to convert multiple avi's to DVD with chapter points between each?
By Pierre1 in forum Newbie / General discussionsReplies: 3Last Post: 6th Aug 2009, 07:38 -
best subtitle program with multiple resync points
By carlos28355 in forum Newbie / General discussionsReplies: 3Last Post: 21st Jun 2009, 21:10 -
how do I compress multiple avi files with virtualdub?
By unloaded1 in forum Newbie / General discussionsReplies: 2Last Post: 1st Mar 2008, 23:43
