I have always used MPEG-1 for coverting files in TMPGenc. I am sampling the MPEG-2 format and really don't know what is the difference between the two. Does it make the transfer look better and what is the advantage between MPEG-1 and MPEG-2
PH
A good place to start is with the Glossary:
https://www.videohelp.com/glossary?M#MPEG-1
-drjtechThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
Main disadvantage of MPEG1: it doesn't support proper encoding of interlaced video.
mpeg-2 allows for higher bit rates, different profiles, higher resolutions, it can be muxed with ac3 (though it may be possible to mux mpeg-1 with ac3), it provides for more complex encoding parameters, basically if all you are doing is 320x240 at 1mb/s stick with mpeg-1, if you plan on doing dvd and greater resolutions you go with mpeg-2 and there are some that will tell you that hi def should be done with avc (but i'm not one of them).Originally Posted by PHNeedsHelp
MPEG-4 ~ what's the difference?
By kr236rk in forum Video Streaming DownloadingReplies: 15Last Post: 3rd Feb 2016, 09:31 -
mp4 xvid vs H264 mpeg-4 avc quality difference
By johnharlin in forum Video ConversionReplies: 2Last Post: 8th Apr 2012, 08:38 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
Time difference between VOB and MPEG
By sambat in forum Newbie / General discussionsReplies: 6Last Post: 18th Aug 2008, 16:06 -
Archos 404 & DVR stand vs Archos AV 500 - difference in MPEG-4 recordin
By DavidMcGowan in forum Capturing and VCRReplies: 0Last Post: 4th Aug 2007, 06:49
