Hello,
I have edited a film with Avid Mediacomposer. I want to author it in Encore. The problem is that Encore does not do a proper transcoding of a Quick Time reference or Quick Time movie. So what I need is a tool that converts a Quick Time Movie into High Quality MPEG2 (ready for burning). Or would it be better to create an .avi in Avid Mediacomposer and convert that to MPEG2?
What would be a good recommendation for a cheap but good converter? I don't want to spend hundreds on Sorenzen squeeze or comparable.
Thanks,
Rob
Results 1 to 13 of 13
I love it when a plan comes together!
AVStoDVD can process mov files, only if a suitable directshow audio codec is installed. You can try with ffdshow or with Quicktime Alternative.
Bye -
Have you tried with Quicktime Alternative?
Bye -
I can't install QTAlternative. I will have to uninstall the regular/official Quicktime Player. My Avid Media Composer software will complain about these changes, I fear.
Don't you thinks so? -
Another source filter option in avisynth is qtsource, which utilizes the installed QT on your system.
QTInput("video.mov")
Quicktime Reference might be giving the other suggestions problems. You could export a lossless format wrapped in mov instead e.g. uncompressed, png, animation , or even visually lossless like DNxHD or ProRes
On windows it would be better to export lossless AVI from Avid eg. lagarith, huffyuv, UT etc...
Choppy Video- Hard to watch in Quick Time
By RS4425 in forum MacReplies: 5Last Post: 1st Sep 2010, 15:03 -
Quick time reference (.mov) also readable with WMP?!
By B-Twien Bytes in forum Newbie / General discussionsReplies: 3Last Post: 4th May 2009, 11:37 -
using quick time video clips in windows movie maker
By benmar in forum Newbie / General discussionsReplies: 2Last Post: 7th Aug 2008, 10:43 -
Quick Time Pro Help
By Soccerman77 in forum Video ConversionReplies: 1Last Post: 14th Dec 2007, 10:38 -
Quick Time Failure, HELP
By jackboyko in forum ffmpegX general discussionReplies: 1Last Post: 25th May 2007, 13:41
