  1. Member MarioB's Avatar
    Mar 2005
    Ovar, Portugal
    Hi all,
    I'm using VirtualDub MSU Cartoonizer Filter to 'cartoonize' some home made videos I made with my kids. Although the processing mode is extremely slow, it seems the final results are pretty good except the following: the original aspect ratio of my films is 16:9, but the final film I get (*.avi) is 4:3 with both sides squeezed. Well, I'm not a VirtualDub expert, so maybe I'm doing something wrong...
    Can you please tell me what options/configurations I must change in VirtualDub to keep the original aspect ratio on the final film?
    Thanks in advance,
    Mário
  2. VirtualDub ignores aspect ratios. It deals only in pixels. If you want to set a display aspect ratio (DAR) or pixel aspect ratio (PAR) you have to do it in the output compression codec. If the compression codec doesn't support PAR/DAR flags you manually specify the aspect ratio in whatever program is later reading the file.
    USA
    VD doesn't honor aspect ratio flags. You might run it through MPEG4 Modifier to see if that would correct it. I would expirement on a copy, though.
  4. Rather than setting a DAR/PAR, I'd recommend just resizing prior to encoding. If they're really 16:9 (and 720x576?), maybe try 624x352 or some other roughly 1.78:1 ratio.
    And if they were originally 720x576, the output isn't 4:3 but the original 5:4 (720/576=1.25). Like they said, VDub ignores the DAR.
