Greets folks.. I have had this Sony S300 player for a little over a year and I use dvd2svcd to "rip". I then take the bbmpeg files and use simple demux under mpeg tools in Tempg to make a svcd compliant vcd. (this is supposed to give you the quality of an svcd which will play on a vcd only player). Once complete I use vcdeasy to burn my backup, the procedure is posted here on Doom9 site if anyone interested ... http://rilanparty.com/vbb/showthread.php?s=8fb5d876b3d8dc48407cae6b1dcedb11&threadid=16404 Anyway this works great on my puter except when I play it on my standalone player the picture on my TV is in the lower half of the screen and cut off. Really sux. Any ideas on how to fix? Please don't tell me I need a new player... can't afford it. Any ideas how to fix....![]()
You know your getting old when you get the same sensation from a rocking chair that you used to get from a roller coaster....
I've got the same problem with my Pioneer 525 dvdplayer, except my menupages are full screen....... go figure.
I had the same problem with my S300 so I ended up burning them as XVCD instead and it worked fine. Let me know if you find the solution
blu ray player firmware update removes media compatibility sony bdp-s300
By cdcutlip in forum DVD RippingReplies: 9Last Post: 8th May 2011, 02:03 -
issues playing burned DVD's on sony blu ray player bdp-s300
By cdcutlip in forum DVD & Blu-ray PlayersReplies: 2Last Post: 7th May 2011, 15:12 -
Can't capture video with Sony Vegas using my HP media center
By fuzzblaster in forum Capturing and VCRReplies: 3Last Post: 2nd Sep 2010, 09:45 -
I have a Sony BDP S300 BluRay player, and the menu
By tzm in forum Authoring (Blu-ray)Replies: 2Last Post: 27th Mar 2008, 02:20 -
VCR to Sony Media Center computer
By billroddy in forum Capturing and VCRReplies: 1Last Post: 31st Jul 2007, 08:32
