All I want to do is convert some DVD-RAM material to DVD-R...
No problem I thought, download the trial version of TMPGEnc 4.0 Xpress on my desktop (running Vista) to see what the conversion quality it is like.
Using the source wizard to import the clip from a DVD-RAM disc I get this error message:
Unsupported File (error code 0x80048003)
Not a good start and searching the net provides little information on this. Importing other formats on disc such as WMV works fine, the issue only appears to be with RAM.
I downloaded TMPGEnc 4.0 Xpress to my laptop which is running XP and using the same disc the source wizard recognises it and imports the file, no problem.
I then check to see if it is a hardware error with my DVD-RAM drive by connecting an external drive to my desktop PC, still no go, same error meessage as above. Just to check the external drive also works with the laptop, TMPGEnc recognises the file.
On my desktop if I copy the complete 'RTAV' folder to the hard drive and using TMPGEnc I import the VRO file directly, this way it recognises it allowing me to do the conversion!
There we have it, a rather sorry state of affairs, hopefully there might be some ideas on what could be wrong?
There seems to be some conflict with the TMPGEnc software, because a few weeks ago when I tried the authoring software that would not recognise the DVD-RAM discs either.
Thanks in advance,
the colonel
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
Tmpgenc Xpress 4 stream reading error
By WinSpecToR in forum Video ConversionReplies: 8Last Post: 16th Oct 2008, 07:50 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
