Hi
I wanted to convert mkv file to avi and I found out that very good program is Alltoavi. I installed CCCP (Combine Comunity Codec Pack) and installed the program and when I tried to convert .mkv file everything went nice. Perfect quality of video but not sound at all. I don't have any idea what's wrong or what I'm doing wrong. I try couple times with different files and the same (no sound)
Can someone help me and give me so advice what to do ?
Thanks in advance
P.S.
When I start program (Alltoavi) always there is very loud music and I don't know how to switch it off. Can someone tell me how? PLEASE !!!!
JKoniak
Drop the AllToAVI file into MediaInfo and see if it shows any sound. Sometimes the output sound isn't compatible with your playback device/program.
If there is no audio there, then check the MKV file with the same program and see what audio format it has. You can post both results here. (Screenshots of both are good.) -
Hi
This is what I've got:
[img=http://img691.imageshack.us/img691/1343/88647492.th.jpg]JKoniak -
Alltoavi probably doesn't support dts audio. So try instead a tool that has been updated this year...like Handbrake, load the mkv, choose avi and convert. Other tools you can try are format factory, any video converter free, winff.
Alltoavi
By jarko in forum Video ConversionReplies: 4Last Post: 28th Nov 2009, 08:43 -
alltoavi help..
By helper in forum Video ConversionReplies: 6Last Post: 28th Jul 2009, 13:23 -
AllToAvi
By natty in forum Newbie / General discussionsReplies: 3Last Post: 10th Jun 2008, 15:49 -
Quantizer in Alltoavi
By drstew in forum Portable VideoReplies: 1Last Post: 30th Mar 2008, 15:34 -
ALLtoAVI keeps crashing. Does anybody know...?
By hellfire45 in forum Video ConversionReplies: 5Last Post: 20th Feb 2008, 15:01
