Hi
Could you please tell me if there is an app that could help me arrange my folders & files to the exact dvdr size?
i have lots of thing to burn. & i try to find the best combination of files & folders so it will be exact 4.37Gb
So i find myself trying & trying different combinations of files all day long. is there an app for that?
(nero could do it?)
thanks
Use an archiving or backup tool (7zip, Macrium Reflect, Toucan etc.) and use the option to split files at the desired size. Most of these apps will have DVDR size as a built in option, and many of the backup utilities will allow you to burn directly to DVD (if you are short of disk space).
Slainte
middersVolunteer for https://www.computersforkids.org.uk/ -
Originally Posted by JekylHyde
Why is that not a solution? The files will stay as they are...
they will stay as they are inside a zip. i need them as they are not inside anything
http://hcidesign.com/dvdspan/manual.html
And filling the DVDR to the maximum is NOT a good idea. -
well, it is a better solution. thanks.
but the problems here are that somtimes i give it several folders to arrange & it take only several files out of these folders. i need it to arrange the folders as they are to a dvd size, not taking only several files out of folders. i used all 3 options there...
echo cancellation, auto volume, auto gain
By pror0ck in forum AudioReplies: 1Last Post: 10th Sep 2011, 07:01 -
How to disable auto-arrange in windows 7 folders
By johns0 in forum ComputerReplies: 0Last Post: 17th Nov 2010, 21:17 -
Media Player Classic: Auto Zoom: Auto Fit logic
By DRP in forum Software PlayingReplies: 0Last Post: 29th Apr 2010, 09:59 -
Is it possible to re-arrange right click
By mn072065 in forum ComputerReplies: 2Last Post: 11th Jun 2009, 23:20 -
How do I arrange vob files
By belaghastly in forum EditingReplies: 2Last Post: 11th May 2007, 05:03
