    Aug 2001
    Hi, i was wondering if anyone has any ideas of whats the best codec(container) to use..
    for years i would use avi with divx, xvid, etc. and lately i have been using mkv...
    also i have been putting all my files in mkv but not sure if thats the best format for quality..
    i dont care about size.... i want perfect quality and sound...
    any suggestions
    thanks
  2. Originally Posted by crazydrve
    The original format (but it won't be perfect since there's no such thing).
  3. Member fitch.j's Avatar
    May 2009
    Uncompressed, Assuming your machine can 1. Handle playing it back (doubtful) and 2. has the room to store it (more doubtful)
    You have to care about size.
    Aug 2001
    i have the speed and power... plus i have plenty of storage... building a media server...
    i will probably just go with mkv for now with some testing...
    Jul 2009
    Spain
    mkv is just a container and has no effect on the 'quality' of the contents.
  6. Member zoobie's Avatar
    Feb 2005
    Florida
    like johnny said, the original format
