hi i am a newbie i think the dvdfab range is great it will burn things that even dvd shrink cant-however when i start it up put in the original disc the whole program seems to turn off whats going on? bizarre any assistance will be most appreciated jessiepal38![]()
Does it just happen with that dvd or all dvds?
Another option would be to use/install anydvd and then shrink using dvd shrink. -
Are you still using DVDFab 5, as the subject says? I would recommend first that you install the current version of DVDFab (6.2.0.5 as of today) and try again.
-drjtechThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin
