Hi everybody
In the past couple of days, I've experienced a new thing with my pc, I suddenly get a strange annoying sound in my speakers and the computer freezes and I can't do anything anymore, but restart or unplug...
Any idea? I have recorded the sound but I don't know who to upload it here so you can hear it...
Following are possible fixes.
do you re-boot regularly
scan with :-
http://www.filehippo.com/download_ccleaner/
do you have up to date anti virus working
go into control panel uninstall the sound card and re boot which reinstalls the drivers.
running xp or what?PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
HiOriginally Posted by victoriabears
I don't re-boot regularly
I do have an anti virus working and it is up to date
I am running, windows 7, 32bit -
computers should be re-booted at least once a week and scanned for garbage files which can trip over the operating system.
A kind of sound like the last bit of audio is stuck and just repeats rapidly, kind of a stuttering sound? If so, that's a system lockup. Reboot and it goes away?
Malware issue ... doubt it
1: Remove all non-essential external devices and run in this state for 12 hours ... if noise disappears then external device was cause
2: Uninstall the audio device , reboot, reinstall, reboot ... if still exists, move on down list
2: Check psu (replace test) ... faulty psu's can emit strange noises through speakers
3: Check buttons from case are not damaged (melted connections)
4: Check mainboard (loose connections, leaking caps, blocked fans, poor quality heatsink compound)
Clean system garbage regularly
System reboots are only required regularly when system performance has decreased over time ... thou it was common with xp needing to be rebooted after X number of days or issues would develop ... All microsoft operating systems have this issue -
Thank you guys very much for the information. I will check everything that you mentioned and see what's causing this...Originally Posted by Bjs
Before you spend hours doing other things, first try to boot into Safe Mode. If the freezing stops and your unit runs normally, you have a software/driver conflict. Another thing is to download Memtest 86+ (free) memory test, burn the ISO to a CD and boot from your CD/DVD to test your memory. Sometimes bad memory will freeze a computer, and it can send a signal through the speakers.
VHS to DVD, no Picture Noise. Remuxed it, now it DOES have Picture Noise
By VideoFanatic in forum RestorationReplies: 53Last Post: 20th Sep 2011, 20:42 -
Strange noise
By alintatoc in forum ComputerReplies: 3Last Post: 9th Jun 2011, 15:08 -
Big proble here! Camcorder is producing a strange noise
By Fidla in forum Newbie / General discussionsReplies: 10Last Post: 8th Sep 2010, 09:46 -
Removing noise from video that's possibly from aerial noise/broadcast/vhs
By filnads in forum RestorationReplies: 10Last Post: 11th Jan 2010, 01:57 -
Strange sounding bass like noise when capturing from VHS. Help.
By Bricktop in forum Capturing and VCRReplies: 3Last Post: 9th Feb 2009, 10:21
