    Nov 2009
    Iceland
    Hi,
    I'm kind of new to this video conversion scene...
    But my problem is that I have a .mkv files that are in 1080p format and I need to change them to 720p.
    My reason for this is space issues. I want to shrink the size of my collection.
    These 1080p files that I have are around 8GB plus. I want them down to around 4.2 - 4.5GB
    Any ideas?
    Here is the 1080p specs that I got from MediaInfo
    Video
    Format : AVC
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Muxing mode : Container profile=Unknown@4.0
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 1h 37mn
    Bit rate : 10.8 Mbps
    Nominal bit rate : 11.1 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 23.976 fps
    Resolution : 24 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.218
    Stream size : 7.34 GiB (92%)
    Writing library : x264 core 75 r1247 b3efbe5
    Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=11072 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
    Language : English
    And here is a sample of how I want it to be like.
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings, ReFrames : 5 frames
    Muxing mode : Container profile=Unknown@4.1
    Duration : 1h 56mn
    Bit rate : 4 622 Kbps
    Nominal bit rate : 4 731 Kbps
    Width : 1 280 pixels
    Height : 536 pixels
    Display aspect ratio : 2.35:1
    Colorimetry : 4:2:0
    Bits/(Pixel*Frame) : 0.281
    Stream size : 3.76 GiB (86%)
    Writing library : x264 core 67 r1153M 7b6ce6a
    Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=4731 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
    Language : English
    canada
    Or handbrake.
    Nov 2009
    Iceland
    Thanks for the reply guys,
    I'm trying uncropMKV at the moment at it is very simple and straight forward for me! Thanks johns0
    Regards
    oskar
