Hi, Just burned a copy of a radiohead live DVD.
DVDR is normal, and the radiohead file I burned is NTSC format (I think) and burned in VIDEO_TS folder with proper VOB files.
Works fine on my computer or playstation
Won't work on my Sony DVD player - can it not play burned DVDs no matter what?? No way around this?
Does this mean it won't work on most players then?
	What program did you burn with?
 What brand of discs do you use?
 There were some OLDER Sony players made that did not play anything home-burned....including CD-R too.
 You THINK it's NTSC?
	I used SwiftDisk Burning Wizard Premium 2.30
 I used Verbatim DVD-R v2.1 discs
 I think it's NTSC because because it doesn't give me a white screen as with the European format, it just says "Cannot Read" on the DVD player as if the disc doesn't work. But it works on my pc just fine!
  Problem burning data DVD using Nero 6 burning romBy thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14
  DVD burning problemBy eunhye in forum Newbie / General discussionsReplies: 7Last Post: 7th Sep 2008, 21:04
  DVD Burning problemBy eXit- in forum Authoring (DVD)Replies: 7Last Post: 1st Aug 2007, 11:42
  DVD burning problemBy Neil_2004 in forum DVD RippingReplies: 12Last Post: 30th Jun 2007, 19:14
  DVD burning problemBy ea7770 in forum Newbie / General discussionsReplies: 1Last Post: 25th Jun 2007, 16:17
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
