Hello,
I am trying to rip the audio from a concert DVD I own but the high end is coming out pretty muddled. I have tried a few different DVD audio ripping programs and I'm getting the same result, which is a pretty muddled high end. As mentioned I've tried a few different programs but they're all giving me the same result. Any thoughts?? Thanks
"Ripping" a DVD results in an EXACT copy of both audio and video....so what you are implying is either impossible or "all in your head".
What have you tried? Maybe the programs you used converted the audio , instead of keeping the native format?
How are you playing it back? What software/hardware setup? Maybe it's a playback issue? -
hech, I know ripping the file (dvdshrink) creates an exact duplicate, and I've done this process many times before, which is why I'm surprised I'm suddenly running into these problems.
Poison, I have tried a variety of programs, including DVD Audio Ripper (my old standby) and ZC DVD Audio Ripper (which keeps crashing on me). I have also tried converting the files to mpeg and extracting from there using dBpoweramp but I just get garbage (inaudible) output. I also tried importing the files into audacity but again it's just muddled on the high end!
I'm using a pc with vista by the way.... -
Poison what program could I use to ensure that the audio is kept in a native format?
Thank you for your input.
Sources for high-end VCRs considered
By sanlyn in forum Capturing and VCRReplies: 0Last Post: 29th Jan 2012, 08:57 -
How do I rip a DVD, trim part of it (beginning & end), and copy onto DVDs?
By aple in forum Newbie / General discussionsReplies: 5Last Post: 11th Jul 2011, 18:04 -
low end quadro is 5 times faster than high end gaming card
By deadrats in forum ComputerReplies: 4Last Post: 7th Apr 2011, 15:42 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 17:24 -
Software Encoding on High-End System
By tbradyjd in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2010, 21:36
