Hi
I wanted to convert mkv file to avi and I found out that very good program is Alltoavi. I installed CCCP (Combine Comunity Codec Pack) and installed the program and when I tried to convert .mkv file everything went nice. Perfect quality of video but not sound at all. I don't have any idea what's wrong or what I'm doing wrong. I try couple times with different files and the same (no sound)
Can someone help me and give me so advice what to do ?
Thanks in advance![]()
JKoniak
You could try AVIDemux instead, or for greater control, do it in several steps:
- demux mkv with MKVToolnix
- index with DGAVCDec (if H264/AVC)
- frameserve with AviSynth
- use VirtualdubMod to encode to Divx (use free Xvid codec)Volunteer for https://www.computersforkids.org.uk/ -
When will people listen to 99% of the population and STOP installing codec packs?
USE a newer and more updated program like handbrake, format factory, etc. See https://www.videohelp.com/tools/sections/all-in-one-video-converters?orderby=Updated
Guys, thank you so much for info and some advices. !!!!
P.S.
I'm not able to open .mkv file in VirtualDub. Why?
I try Alltoavi. I'm not sure if I like it but some thing is really annoying. When I start program always very loud musik appeares and I would like to switch it off. Can someone tell me how? PLEASE !!!!JKoniak
Alltoavi - help !!!
By jarko in forum Video ConversionReplies: 4Last Post: 1st Dec 2009, 14:41 -
alltoavi help..
By helper in forum Video ConversionReplies: 6Last Post: 28th Jul 2009, 12:23 -
AllToAvi
By natty in forum Newbie / General discussionsReplies: 3Last Post: 10th Jun 2008, 14:49 -
Quantizer in Alltoavi
By drstew in forum Portable VideoReplies: 1Last Post: 30th Mar 2008, 14:34 -
ALLtoAVI keeps crashing. Does anybody know...?
By hellfire45 in forum Video ConversionReplies: 5Last Post: 20th Feb 2008, 14:01
