Hello
Normally i have my sony hdtv connected to my pc (8600gs running on vista 32bit). It's connected with hdmi on tv side and hdmi/dvi adaptor on the pc side.
Up until a week ago it all worked fine. Then one night i heard a loud pop, but everything still worked. The next day my pc did not recognize my tv anymore and i still haven't found the solution. It just does not show up anymore in the nvidia control panel.
What could be the problem? I tested everything i could.
- the hdmi cable works fine on other devices.
- I tried a newr hdmi/dvi adaptor, but still no screen.
- i connected a dvi - dvi cable on a regular pc screen and it works fine. So the port that connects my pc to my tv should be fine i guess.
- The hdmi ports on my tv work, i tested them with other devices.
- a vga cable to the tv gives the pc screen on my tv, but offcourse in worse screen quality then a hdmi cable.
- I installed the newest nvidia drivers
It's driving me mad, who will save me.
Thanks in advance for any help
Edit: I just saw that sometimes when the tv is switched off my pc detects it, but the second i turn my tv on it doesn't detect the tv anymore. I can see that in my nvidia control panel...
Results 1 to 1 of 1
libx264 detection
By rzippert in forum LinuxReplies: 1Last Post: 24th Feb 2012, 09:31 -
Do Samsung HDTV's have an RF antenna connector for receiving off-air HDTV?
By pianopeddler in forum DVB / IPTVReplies: 2Last Post: 6th Aug 2008, 22:43 -
Need al little help getting my new ati hdtv pci card to sense HDTV channels
By MidnightMike in forum ComputerReplies: 8Last Post: 23rd Jul 2008, 03:12 -
Problems with connection with my Panasonic HDTV and Timewaner HDTV box...
By S4one in forum DVB / IPTVReplies: 7Last Post: 2nd Nov 2007, 23:39 -
Enigmavision HDTV - HDTV viewer software for ATSC TV tuner cards.
By gc04 in forum Latest Video NewsReplies: 9Last Post: 7th May 2007, 01:32
