I'm looking for how to re-encode my m2t video files into .mov files using the quicktime animation codec. Is this possible?
I know little about ffmpeg command lines, i was trying to use WinFF as it seemed to be more intuitive,
I had the preset command line as:
But it threw up an error.Code:-f mov -acodec libfaac -ab 128kb -ac 2
I'm not looking to change anything else, resolution framerates etc all to be kept.
Any help would be great, thanks.
If it helps this is what mediainfo says about the source file:
Code:ID : FF Complete name : G:\Video Footage\Test Cap-2009_10_20-16_01_51.m2t Format : MPEG-TS File size : 21.3 MiB Duration : 6s 759ms Start time : UTC 2009-10-20 16:01:51 End time : UTC 2009-10-20 16:01:58 Overall bit rate : 26.4 Mbps Maximum Overall bit rate : 33.0 Mbps Encoded date : UTC 2009-10-20 16:01:51 Video ID : 2064 (0x810) Menu ID : 100 (0x64) Format : MPEG Video Format version : Version 2 Format profile : Main@High-1440 Format settings, Matrix : Default Duration : 6s 720ms Bit rate mode : Constant Bit rate : 24.2 Mbps Nominal bit rate : 25.0 Mbps Width : 1 440 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 25.000 fps Standard : Component Colorimetry : 4:2:0 Scan type : Interlaced Scan order : Top Field First Bits/(Pixel*Frame) : 0.622 Stream size : 19.4 MiB (91%) Audio ID : 2068 (0x814) Menu ID : 100 (0x64) Format : MPEG Audio Format version : Version 1 Format profile : Layer 2 Duration : 6s 528ms Bit rate mode : Constant Bit rate : 384 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Resolution : 16 bits Video delay : 48ms Stream size : 306 KiB (1%)
Results 1 to 11 of 11
What is the error from ffmpeg?
Another option would be to try mpeg streamclip and see if it can open the mts. -
Ok great thanks i managed to sort it out and 'qtrle' was what i needed to know.
Another couple of questions: Firstly i'm assuming that is at quality 100 yes? It seems like it to me but just checking.
And also what would be the codec name for Photo-JPEG ? I'm looking around now for a list of codec names for ffmpeg but not able to find them yet, i thought that would be a top google result! :/
Cheers for the fast responses and help guys. -
animation codec is lossless, so yes quality is "100%", but there is a colorspace conversion to RGB. Converting back to a YV12 format isn't lossless.Firstly i'm assuming that is at quality 100 yes?
also beware of the "QT gamma shift bug". Google. This may or may not affect you depending on what you are doing and your platform, how you play your files.
ffmpeg -formatsI'm looking around now for a list of codec names for ffmpeg
to see what your specific build supports / codec names
There is a list if you scroll down here, but not all builds may have compiled support:
http://t.webofgoo.com/2008/08/10/ffmpeg-convert-any-audiovideo-format-in-linux/comment-page-1/ -
Ok, Thanks for that link that was exactly what i was looking for.
I tried simply changing the codec from 'qtrle' to 'mjpeg' however now i'm getting the error "error while opening for output stream #0.0 - maybe incorrect paramaters such as bit_rate, rate, width or height"
However i haven't defined these in the command line so i'm not sure what needs to be changed, and what paramaters Motion-JPEG requires to be told rather than just copy the source file.
What i ran and worked fine for Animation was:
However i'm getting the error when running this for mjpeg here:Code:-f mov -vcodec qtrle -ac 2
Code:-f mov -vcodec mjpeg -ac 2
Once again all help is very much appreciated! -
Not sure, it might be that mjpeg requires 1:1 square pixel format. It might not support anamorphic like your source (just guessing)
Also, mjpeg comes in many, many different "flavours" , from different colorspaces, different compression from very lossy to lossless, etc... Not sure what one you're getting by using ffmpeg. So it might be you have to specify a bitrate (not sure) -
Hmmm, i can't work it out. I just rendered this out as photo jpeg (from AE) and it seems to handle anamorphic footage fine.
I'll have to look into it moreCode:General Complete name : G:\Video Footage\Comp 2.mov Format : MPEG-4 Format profile : QuickTime Codec ID : qt File size : 177 MiB Duration : 6s 40ms Overall bit rate : 246 Mbps Encoded date : UTC 2009-11-27 19:34:00 Tagged date : UTC 2009-11-27 19:34:15 Writing library : Apple QuickTime Video ID : 1 Format : M-JPEG Codec ID : jpeg Duration : 6s 40ms Bit rate mode : Variable Bit rate : 246 Mbps Width : 1 440 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 fps Bits/(Pixel*Frame) : 6.338 Stream size : 177 MiB (100%) Language : English Encoded date : UTC 2009-11-27 19:34:00 Tagged date : UTC 2009-11-27 19:34:15
I'm not at home, i'm away with friends for a while and trying to help him with some AE work but he only has the trial version, so importing m2t files is unsupported. I thought if i could easily convert his footage to Quicktime files he could work with them a lot easier, and After Effects likes quicktime files. Unfortunately AE won't do this for him so i went to FFMpeg.
I think he'll be fine with the Animation files i've got here, however i was only looking towards Motion-Jpeg because at 95-100 quality that would be fine for what he is wanting to do, and with Animation thats eating up his hard drive space in no time.
I suppose i could go really longwinded and convert to Animation, and then use adobe to reconvert to Motion-JPEG, but would be nicer if there was one easy step.
Not a dumb question at all! 8)
ffmpeg command lines not working.
By PsyDonias in forum Video ConversionReplies: 23Last Post: 5th Dec 2011, 09:04 -
m2t to DV avi - (SUPER=16:9 flag problem) - (FFMPEG=lots of errors)
By crockysam in forum Video ConversionReplies: 1Last Post: 6th Jul 2010, 06:51 -
Ffmpeg command to encode ENTIRE DIRECTORY?
By sumpm1 in forum LinuxReplies: 2Last Post: 27th Sep 2008, 08:40 -
Help with FFMPEG command lines
By ricardouk in forum Video ConversionReplies: 11Last Post: 17th May 2008, 12:27 -
Get corresponding ffmpeg command after using ffmpegX
By npw in forum ffmpegX general discussionReplies: 2Last Post: 23rd Apr 2008, 01:29
