hi
how can i take sections of MP4 file from camera
that is already coming compressed
and cut sections in direct stream copy or something which doing it fast such as doing in VD in avi files?
thanks
Results 1 to 11 of 11
It works similar to vdub:
1) mark in/mark out to cut to the section you want to keep. It's not frame accurate, so your final navigation point has to be on a keyframe (use << and >> buttons) , use A/B for the mark in / out points
2) set video=> copy , audio=> copy, format=> mp4
3) press save & enter extension (e.g. "myvideo.mp4") -
thanks body
i did it
and went to save - save video - gave it a name and press ok
and i had error
I get the same often with files from a GoPro HD camera. Go to Edit --> reset edits and try marking the points again. If it still gives you grief try closing the application and launching it again.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
10x bodies works gr8
just remind me how can i join those mp4 files into 1 file?
Cutting video sections with Virtualdub without recompressing
By rantpolicy in forum EditingReplies: 11Last Post: 16th Apr 2012, 06:48 -
Stripping sections of MKV files to seperate smaller MKV files
By spudz72 in forum EditingReplies: 6Last Post: 29th Jul 2010, 01:53 -
Cutting HD files
By surfer in forum EditingReplies: 2Last Post: 23rd Jan 2010, 13:06 -
cutting FLV files
By shaema in forum EditingReplies: 2Last Post: 24th Sep 2009, 11:01 -
Cutting VOB files
By DELTAsnake in forum EditingReplies: 20Last Post: 6th Apr 2008, 16:23
