does anyone know how to capture a batch of still images from video using mencoder?
what is the command that can do that?
i can always use ffmpeg on most of video files,but ffmpeg does not support rmvb so i need to use mencoder for this matter
since i'm not familiar with mencoder,i need help from you guys
	Try mplayer with -vo jpeg
 mplayer -vo jpeg <video file> and mplayer -vo png <video file> output
 video into jpeg and png files respectively.
 -osdlevel 0 suppreses volume + seek from appearing in the images
 -sstep <sec>
 Specifies seconds between displayed frames. Useful for slideshows.
 -ss <time> (see -sb option too)
 Seek to given time position.
 EXAMPLE:
 -ss 56 seeks to 56 seconds
 -ss 01:10:00 seeks to 1 hour 10 min
 -frames <number>
 Play/convert only first <number> frames, then quit.
	does mplayer support rmvb without the codec files?Originally Posted by Baldrick
  Capture Images from HD video clipBy amigo_rk in forum Newbie / General discussionsReplies: 1Last Post: 30th Oct 2011, 22:22
  Mencoder (Ubuntu) with Logilink Video Grabber VG0001 -> video buffer fullBy Dobi in forum Capturing and VCRReplies: 0Last Post: 6th Jul 2010, 11:52
  Ubuntu+mencoder+Pinacle dazzle capture issuesBy mankeletor in forum LinuxReplies: 0Last Post: 21st Jun 2010, 09:33
  Capture tv signal with mencoderBy mierdatuti in forum Capturing and VCRReplies: 1Last Post: 2nd Feb 2009, 02:39
  Video Capture with Mplayer, Mencoder or ffmpeg under Winxp. Is it possible?By gll99 in forum Capturing and VCRReplies: 0Last Post: 11th Sep 2008, 19:00
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
