I am trying to capture video (and audio) from a TV source (mainly VHS player, but also analog cable).
But the audio becomes progressively out of sync (slower) with the video. This also happens when just playing the captured video (as opposed to recording it on disk).
The stats:
Linux, F11.
P4 2.6GHz, 2G RAM
Pinnacle PC Pro capture card (Conexant chip)
I have tried FFMPeg, and Mencoder/MPlayer. Both give the same results. After about 10 min, the audio is about 3 to 5 seconds behind the video. And that offset continues to grow as the video progresses. I last tried Mencoder, with the following command:
mencoder -tv device=/dev/video0:input=1:adevice=/dev/dsp1:amode=1:immediatemode=0:audiorate=48000:mjpeg :decimation=1:norm=ntsc -vf harddup -vf expand=::::0:1 -mc 0 -o /mnt/xfs/vhs.avi -noskip -forceidx -ni -oac copy -ovc raw tv://
Any help with this will be greatly appreciated (a lot of good karma).
TIA
ken
The simple answer is your video and audio files are likely different lengths. What part of your procedure is causing it may be a bit more complicated.
And welcome to our forums.
Yes that is a simple answerOriginally Posted by redwudz
But there are no "files" involved. This is capturing the video/audio stream from a tv source (via capture card).
I am wondering how/why the two streams become different "lengths". As I said, the out-of-syncing is progressive - it gets more as the capture continues. I noticed that after about 5 minutes captured, the audio is "stretched out" past the video by about 1 second; after about 10 minutes, it becomes 3+ seconds.
I should try to capture the video and audio separately (two passes), then mux them together.
Thank you.And welcome to our forums.
ken
Avi to DVD - audio goes progressively more out of Sync
By UnknownVT in forum Video ConversionReplies: 9Last Post: 11th Jan 2012, 13:33 -
Audio goes progressively out of sync. Calculate the "rate of change"?
By rayden54 in forum AudioReplies: 1Last Post: 26th Sep 2010, 07:48 -
Problem with audio gradually going out of sync in ts file (captured video)
By shadowofanubis6 in forum Newbie / General discussionsReplies: 0Last Post: 28th Feb 2010, 11:12 -
Audio sync problems when re-coding captured video. Any Solutions?
By uart in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 17:34 -
Captured Video Out of Sync
By tumaz in forum RestorationReplies: 1Last Post: 9th Jan 2008, 19:55
