  1. Banned
    May 2006
    using ConvertXtoDVD V4.0.5.315 , latest version, converting about 7 videos [ about 44 mins], I think is .avi or RMB, chinese soap Opera series.
    Packed them all in a DVD-5, noticed the quality is pretty good, except, that the sound is kinda out of sync , like the voice will come on first , before I aee the charcters moving their lips..help please?
  2. Banned
    Freedonia
    Is the audio in the soruce videos VBR (Variable Bit Rate)? This is often the cause of sync problems. You may have to use a tool like Gspot or something similar to determine what kind of audio is in your source files.
  3. Banned
    May 2006
    I am NOT sure it is or nOT VBR?
    Might be that I am packing in too many Vidoes in a DVD-5, let me observe one that has 6 Videos in it, that way I can compare them. Thanks.
  4. Mod Neophyte redwudz's Avatar
    USA
    Shouldn't make any difference how much video you put in there. The more video, the lower the quality, but that doesn't have much of anything to do with sync errors. VBR audio, dropped frames, not using the original audio offsets, corrupted audio or video files and other problems are more likely to cause sync errors.
    Did you batch convert them? If you convert them individually, do you have the same sync errors? And do the errors gradually get worse as the video plays or does the error stay the same throughout the length of the file?
  5. Banned
    May 2006
    Batch convert, and really NOT feasible to convert 1 at a time, been doing this for quite a why, and must be a setting of some sort in ConvertxtoDVD in ther Audio Tab, never had this problem with Version 3X
