Hi, I'm new here and also to subtitling video. The case is this:
I downloaded an .flv from Utube, converted it to .flv with FreeFLVConverter.
I made subtitles using SubtitleWorkshop and saved the file as .ssa
Started VD, imported .flv according to the guidelines.
Used subtitlefilter acc. to guidelines
Imported .ssa file and pressed previewkey. That doesn't in the movie with subtitles in the righthand screen.
Please HELP!!Can anybody tell me if the .ssa and .flv have to be in the same folder or something? Is that the cause of my miseery?
Thanks in advance.![]()
Videodub? Virtualdub?
You could also try avidemux, load flv, under video choose a video codec like mpeg xvid, under filters add the subtitle filter and load the ssa. Last save as a new avi.
How to make a small file with videodub?
By benvid in forum Video ConversionReplies: 5Last Post: 22nd Feb 2010, 08:42 -
VideoDub help
By windranger in forum Newbie / General discussionsReplies: 7Last Post: 16th Mar 2008, 01:59 -
problem with videodub movie subtitles
By m-man in forum EditingReplies: 6Last Post: 26th Jan 2008, 20:38 -
When i join ssa+avi the video is messed up
By noskid21 in forum EditingReplies: 3Last Post: 17th Jul 2007, 14:02 -
OGM/SSA to AVI
By defiancexr in forum Video ConversionReplies: 2Last Post: 15th May 2007, 00:33
